Sonofawhatthe
We have a sump pump in our home here in Lincoln, NE. Being a Colorado native I'm not overly familiar with them. After recent storms the pump has started it's annual cycle of running frequently. It's been dry a couple of days so now it shouldn't be running however it turns on every 5 minutes or so as it's stuck in a loop of sorts:
The pump activates as the float rises and pumps some volume of water into the pipe and up and out but of course it doesn't pump it all out, just enough to cause the float to fall and then it stops. And the water it just pumped falls back down the pipe into the pit which starts causing the float to rise and sure enough a few minutes later it starts again. A seemingly endless cycle that wastes energy and reduces pump life.
I'm inclined cut into the pipe and put a vertical pipe with a valve. And when I hear this happening I open that valve and allow this water to run down and I can waste-valve-it into the floor drain. I'm not sure about our local codes but I know in a lot of places you can't drain sump water into the sewers. This would be a hack of course and even if it doesn't match ordinances I'm still maintaining the spirit of the law even if it's not the letter. I'd only catch the issue when I hear it but most times I would and that's better than nothing. Thoughts?
How do other folks combat this illogical problem? How do I actually drain the water and not have it continually go up-and-down the pipe unnecessarily?
