Quick Question about No-Hub
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by glnow, Mar 8, 2011.
  1. glnow
    glnow Member
    Mar 7, 2007
    CA
    Is it legal to no have no-hub connection on a vertical vent line that is behind a wall?
    I have a metal vent pipe with a hairline crack that needs to be addressed.
  2. hj
    quote; Is it legal to no have no-hub connection on a vertical vent
    The word "no" in the question does not make sense. Of course it is legal to have them in walls, otherwise we could NEVER install a No-Hub waste and vent system. If "no" meant "not" then the question is illogical, if not ridiculous.
  4. glnow
    glnow Member
    Mar 7, 2007
    CA
    Whoops, many apologies for the confusion caused by the typo in my original post.
    Yes, I was checking to see if it was OK to have the no-hub union behind the finished wall and it sounds like that is allowed.
    Do I need to add some additional bracing to support the vent pipe when I cut into it, so that the pipe above my cut doesn't come tumbling down? If yes, what do I use?
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The obvious answer to that is YES. I am assuming the vent is cast iron, and you do have to clamp it very, very well. Cast iron is very heavy and a flimsy half-a**ed attempt won't cut it. The vent is likely only supported by itself, so when you cut it, it loses that support and will come down fast and hard.
  6. glnow
    glnow Member
    Mar 7, 2007
    CA
    Understood. What type of clamping/strapping system should be used here?
    Sorry, I should say that I'm not going to do myself, it's beyond me and I'll be going with a pro.
    But this info will help me be sure it's being done correctly.
  7. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    The best thing would be a riser clamp but I don't think the big box stores carry them.
  8. hj
    How the vent pipe is installed ABOVE the cut determines whether it is already supported or not. Only someone on site can make that determination, but I have cut very few cast iron lines which were NOT already supported by the piping configuration above the cut.
Similar Threads: Quick Question
Plumbing Forum, Professional & DIY Advice Quick kitchen sink drain and vent question Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Quick vent question (near main stack) Mar 26, 2016
Plumbing Forum, Professional & DIY Advice Quick toilet drain slope question Aug 24, 2015
Plumbing Forum, Professional & DIY Advice Quick Question About Delta RP17454 Pull Down Diverter Nov 20, 2014
Plumbing Forum, Professional & DIY Advice Quick question about water softener. Brine tank is soapy. Is that normal? (with picture) Oct 18, 2014
