Quick kitchen sink vent question
Discussion in 'Plumbing Code Questions' started by PM5K, Apr 29, 2014.
  1. PM5K
    PM5K Member
    Oct 9, 2006
    San Antonio, TX
    The current sink drain runs horizontally approximately 36 inches sloped through base cabinets, then tees off into a vertical drain, with a vertical vent on the other end of the tee.
    There are some guys working on a relatives kitchen and they want to run the drain straight down below the
    house and then run it the same way towards the same vent and drain.
    Basically they are taking what was happening right below the sink and doing it under the house. I'm not sure which code we have here but does that meet either major code?
  2. Terry
    Aug 17, 2004
    You can't use a sink drain for a vent on the floor below.
    If you add a fixture below, you will need to vent it before it enters the waste line.
  4. PM5K
    PM5K Member
    Oct 9, 2006
    San Antonio, TX
    Sorry if I wasn't clear, there is no floor below, it's a pier and
    beam foundation home. Would this be a proper wet vent, against code, or something else?
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    A vent has to go up before or at the point which the drain turns down. A 1-1/2" trap arm can be up to 3-1/2 feet to the vent if necessary.
  6. PM5K
    PM5K Member
    Oct 9, 2006
    San Antonio, TX
    It sounds like you're saying no, since the drain would go down before it hits the trap arm, before that hits the stack/vent.
Similar Threads: Quick kitchen
Plumbing Code Questions Venting using a horizontal drain from kitchen sink OK? Dec 16, 2016
Plumbing Code Questions Kitchen sink vent and large window Jul 21, 2016
Plumbing Code Questions Kitchen Vent location Nov 30, 2015
Plumbing Code Questions Arlington, Texas - Kitchen sink / disposal drain configuration - Compliant? Nov 11, 2013
Plumbing Code Questions Florida/General Pluming Code for Kitchen Sink Piping Sep 3, 2013
