Questions on pouring concrete around new rough-in
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Vinniejt76, Aug 28, 2008.
  1. Vinniejt76
    Vinniejt76 New Member
    Aug 27, 2008
    I moved my rough-in in my basement about 10 feet. I've already rerun the new pvc and I'm about to pour the new concrete back into the trench I dug. Are there any things I should consider before pouring? I'm going to use cardboard around the toilet drain to create the space needed for the flange to fit. Can the concrete be poured right around the new drains? Do I need to replace the vapor barrier? Should I put gravel back into the holes here the drain isnt? should I replaced the wire that I cut out ( the trench is about 12 in wide)? Is there a specific type of concrete I should use? And finally,should the concrete be poured all at once?
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Have you had it inspected yet?
  4. Vinniejt76
    Aug 27, 2008
    yes, its been inspected.
  5. sjsmithjr
    sjsmithjr In the Trades
    Dec 12, 2005
    Geologist
    Knoxville, Tennessee
    Concrete
    Are you planning on bag mixing or having it delivered? Did you saw cut the existing slab? Where are you located (state would be close enough)?
  6. Redwood
    Dec 15, 2007
    Service Plumber
    Also you have refilled the hole...
    How have you compacted the earth?
  7. Vinniejt76
    Aug 27, 2008
    I live in Maryland. I was going to mix bags. It's an area of about 12 feet long and 1 feet wide. Honestly, not a lot of dirt came out of the hole. It was about 4-5 inches of concrete and another 5-6 inches of gravel. I used a saw for some, but mostly a jack hammer.
  8. sjsmithjr
    Dec 12, 2005
    Geologist
    You started out with approx. 4 inches of gravel, a vapor barrier to prevent water vapor and radon migration, and wire mesh to make the 3000 psi slab resistant to cracking.
    I would but the soil back in excavation, compact (hand tamper), put the gravel back in, compact, put the vapor barrier back in, and use 5000 psi high early strength bag mix. If the sand is dry, you may need to wet it a bit to get good compaction. You want the grains to stick to each other; you can make a golf ball sized clump by hand to check. Use the 5000 psi bag mix because when you mix concrete in a wheelbarrow, you rarely achieve the rated strength. Try to resist the temptation to get the concrete too wet.
    Unless you can tie the new wire to the old, I don't think your trench is wide enough to require replacement. If the existing concrete is sufficiently rough (like you'd get from using a demo hammer), the new concrete will key in and won't settle. If you have sections that are slick from top to bottom, consider roughing it up. I don't think it will be necessary to use rebar dowels, but I haven't seen it and I don't know how well the underlying fill will be compacted.
    Someone is bound to come along and say this is overkill, but this is how I would do it.
  9. Redwood
    Dec 15, 2007
    Service Plumber
    Overkill is a good thing!
    For compaction of earth I like to use water.
    I soak until there is a puddle then poke it with a broomstick until the water disappears, repeat and repeat until its not soaking in anymore.
    Then let is sit overnight and it is then about as compact as it can get.
    Where the new concrete is meeting the old I use a concrete bonding agent.
    http://www.google.com/search?hl=en&q=concrete+bonding+agents&aq=1&oq=concrete+bonding+agent
  10. Vinniejt76
    Aug 27, 2008
    Thanks guys, edge is pretty jagged, so the new concrete should "key" into the old pretty well. I don't think I need new mesh because the tench is only 11 inches wide. I'll put the dirt and gravel back in and compact it. Is there a certain type of tape that I should use to replace the new plastic to old?
  11. sjsmithjr
    Dec 12, 2005
    Geologist
    At the local hardware look around the weatherstriping supplies for something like Frost King Polyethylene Tape.
Similar Threads: Questions pouring
Plumbing Forum, Professional & DIY Advice Bathroom planning advice (venting questions primarily) Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Drop ear questions for new hand shower Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Delta Tub Spout Installation Questions Jan 10, 2017
Plumbing Forum, Professional & DIY Advice Closet flange questions Jan 10, 2017
Plumbing Forum, Professional & DIY Advice Zone valve questions Dec 31, 2016
