Questions on ceramic floors and Aquia installation
Discussion in 'Toilet Forum discussions' started by DIYMom1, May 10, 2010.
  1. DIYMom1
    DIYMom1 New Member
    May 3, 2010
    Denver,CO
    Hi Terry,
    I just bought a new Toto Aquia II but am having trouble with the installation directions. on pg.1 it says I need a 11/32 inch bit to install on a cmt/tile floor (which I have). then on page two it says to drill 5/16 inch holes and use the provided plastic anchors on cmt/tile floors. so--
    question 1, do you know what size bit I should be using and if I'm installing on a tile floor do I really need the plastic anchors?
    the second unclear part is using the plastic piece called the socket that sits over the septic drain hole. does the wax ring really go under the socket, this seems to be what the picture is showing but how can that get a tight seal if the wax isn't smooshed up against the bottom of the toilet. If I install it as the picture shows then the rubber gasket of the socket would be next to the outlet on the toilet and the wax would be under that. this is different that any other toilet I have installed and just want to get it right. I would truly appreciate your advice. I did look at your sons installation information but it did not cover these items.
    Thanks
    [​IMG]
  2. hj
    WE don't know what you are looking at, or what you call a "socket".
  4. jadnashua
    The adapter uses wax to seal it to the floor flange. The toilet seals to the adapter via that rubber gasket. Not sure about the holes. I've seen the toilet, but never installed one. Part of the installation is similar to those that use the Unifit adapter, but not exactly the same.
    If the flange is recessed, then you may need two wax rings or one jumbo to get the adapter to seal to the floor. you should feel it squish the wax when you install the adapter.
  5. Terry
    Aug 17, 2004
    Installing the Aquia toilet by Jamie Love
    [​IMG]
    The flange adapter on the right is for the Aquai II.
    You would set a wax seal or two on the closet flange, and then use closet bolts to secure the adapter to the floor.
    The bowl would drop down onto the adapter.
  6. Firemark
    Firemark New Member
    Aug 11, 2009
    Southern NJ
    What's under the Ceramic Tile Floor? Is it on a concrete slab? If so, yes, you need the anchors and larger hole for the bolts to bite into and hold. If over the usual concrete backer and wood subfloor, maybe not. I drilled larger holes just through the tile then switched to the smaller size and did not use the anchors. Sorry, didn't re-read Jamie's instructions but for drilling the holes make sure you use NEW MASONRY drillbits.
  7. jadnashua
    Some ceramic tile (the harder porcelains) are actually harder than a carbide drill bit, so a diamond bit works best. As noted above, the size of the hole you need to make depends on the floor and whether you need an anchor or have enough wood underneath so all you need is a through-hole in the tile.
  8. Firemark
    Firemark New Member
    Aug 11, 2009
    Southern NJ
    That explains the workout I got drilling through the ceramic tiles, even after buying new carbide tip bits, they lasted only a couple of holes. I've also seen posts here that recommend using a hammer-drill vs a standard electric drill. If you don't want to fork over $100 or more for a drill you can rent them.
Similar Threads: Questions ceramic
Toilet Forum discussions Toto Drake Water level questions Nov 8, 2016
Toilet Forum discussions Toilet Flange Questions May 13, 2016
Toilet Forum discussions Toilet Flange Questions Nov 7, 2015
Toilet Forum discussions New toilet install, couple of questions May 26, 2015
Toilet Forum discussions American Standard Toilet Questions Mar 1, 2015
