questions about fittings for sink drain connection
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by outofplumb, Dec 19, 2008.
  1. outofplumb
    outofplumb New Member
    Dec 7, 2008
    Hi all,
    I'm replacing a sink in my bathroom and will need to redo the drain plumbing.
    Now the 2 fittings I have at hand are:
    - an adapter/reducer to connect the sink's 1-1/4 chrome tailpiece (compression fitted) to the 1-1/2 drain pipe (solvent welded), and
    - a 1-1/2 P-trap (solvent weld at both ends, with a "swivel nut" joint on one side of the "U").
    In theory I can see how everything will be put together. But the problem I have is this: I have worked in the past with slip-joint fittings where there is both a nut and a beveled washer (nylon, I guess?); you slip the nut, then and the washer onto the one pipe, and then fasten the nut to the threaded adapter on the fitting.
    However, in both the fittings I have above, there are no washers. I can see that the inside of the nut does not have a flat end; it has a "lip" on it. On the other (threaded) side of the fitting, the inside edge is beveled inward so it seems that the "lip" on the nut fits on the inside of the fitting body. I suppose this is what compresses against the inserted pipe?
    So here are my questions:
    1 - Is that "lip" supposed to take the place of a separate washer?
    2 - Is this type of joint as reliable as a "standard" nut and washer arrangement?
    3 - What happens if I unscrew the joint, either during assembly or some time down the road? Is this type of joint reusable?
    4 - Is it suggested to use teflon "pipe thread compound" on this type of ABS joint? The compound I bought is a "Master Plumber" branded product.
    Will this make a better joint? Is this safe on ABS?
    Hope this is clear. Please ask if you need more info.
    Thanks,
    outofplumb
  2. jimbo
    jimbo Plumber
    1)yes
    2)yes
    3)yes
    4)NO!
Similar Threads: questions fittings
Plumbing Forum, Professional & DIY Advice Fernco and Mission fittings? Questions? Jan 25, 2012
Plumbing Forum, Professional & DIY Advice Questions regarding Fernco Fittings Feb 10, 2010
Plumbing Forum, Professional & DIY Advice 1950 Renovation Questions Tuesday at 10:06 PM
Plumbing Forum, Professional & DIY Advice Bathroom planning advice (venting questions primarily) Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Drop ear questions for new hand shower Jan 24, 2017
