Questions About Brass vs PVC Tub Drain Assembly To ABS Trap
Discussion in 'Shower & Bathtub Forum & Blog' started by DavidSeon, Sep 9, 2012.
  1. DavidSeon
    DavidSeon Member
    Jul 19, 2012
    MS Gulf Coast
    I have a couple of novice questions about tub drains. Because of the tub "the boss" picked out, I think I need to replace the existing drain (Brass to ABS trap):
    with a Kohler slot-type overflow drain:
    I'm a little confused about the size of the Brass tailpiece vs the ABS trap fitting it slides into. The Inside Diameter of the ABS fitting and the Outside Diameter of the existing tailpiece are both right at 1 1/2", with the tailpiece OD maybe a couple of thousandths smaller according to my caliper (obviously, or it wouldn't fit). Is Brass sizing one of the cases where nominal size refers to O.D. rather than I.D., or is this some kind of special tailpipe made to fit into 1 1/2 ABS? In other words, if I order the Kohler drain (which calls out the tailpiece as 1 1/2 O.D.), should I expect it to be the same slip fit into the ABS, using the same type washer and nut as the existing?
    Also, the Kohler drain is available in PVC as well as Brass, for about $50 less:
    Obviously, 1 1/2" PVC wouldn't fit into the ABS trap because the O.D. would be too large. Is there some kind of transition from PVC to ABS I could use to save a few bucks, or are there other advantages to sticking with the Brass?
    Thanks for your patience and help.
    Dave
  2. jadnashua
    Tubular piping for drains, whether brass or pvc, should be interchangable..IOW, they should be the same OD. The same compression fittings should work.
  4. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    If the PVC drain is specified as Schedule 40 (normal ABS/PVC/Galv Drain/Waste/Vent piping size), then it won't fit. Schedule 40 "glued" tub drains are used where there is no
    access to the drain. Brass tubular size drains (no matter what they're made of) with slip-joint fittings require access. The photo you posted looks like it has a Schedule
    40 santee meant to be glued to Schedule 40 PVC trap/piping below.
  5. DavidSeon
    DavidSeon Member
    Jul 19, 2012
    MS Gulf Coast
    Ok, thanks for the replies. Ordered the brass.
    Dave
Similar Threads: Questions Brass
Shower & Bathtub Forum & Blog Installing new tub - newbie questions 31 minutes ago
Shower & Bathtub Forum & Blog Questions About Tub/Shower Faucets Apr 14, 2017
Shower & Bathtub Forum & Blog Demo'd Fiberglass Shower & Installing New Tile Shower But I Have Questions??? Mar 25, 2017
Shower & Bathtub Forum & Blog Shower surround questions Dec 5, 2016
Shower & Bathtub Forum & Blog Sterling Ensemble, Basic questions Oct 22, 2016
