Question regarding replacing a fiberglass tub in a apartment!
Discussion in 'Shower & Bathtub Forum & Blog' started by Chris112, Jan 26, 2009.
  1. Chris112
    Chris112 New Member
    Apr 10, 2006
    New York
    Hi I am trying to replace my fiberglass tub but live in an apartment on the 2nd floor. All the directions I read say to cut out below the tub to remove the plumbing and drains, but I unfortunately can’t do that. What is my alternative to getting the tub out without having access to the first floor? Any advice would be greatly appreciated!
    Thanks
    Chris
  2. jadnashua
    First, you'd need to get access to the edges - the drywall or plaster is covering that up. Then, I'd just take a sawsall and chop it up around the drain. Once you get it released from the drain, you can cart the old tub away. Setting a new tub when you don't have access from below takes some skill...once you get things cleaned out, if you can poke an access hole in the wall at the drain end, you might be able to do it yourself. If not, you probably want to pay a pro to set the tub for you.
Similar Threads: Question regarding
Shower & Bathtub Forum & Blog Quick question regarding overflow pipe. Jan 26, 2007
Shower & Bathtub Forum & Blog Probably a silly question regarding shower taps Sep 21, 2005
Shower & Bathtub Forum & Blog Shower pan question Dec 6, 2016
Shower & Bathtub Forum & Blog Shower surround questions Dec 5, 2016
Shower & Bathtub Forum & Blog Tub Overflow Valve Question Oct 24, 2016
