Mrmichaeljmoore
I have an Amana AMH95 (Model # AMH950703BX).
Installed in January 2007.
Just a quick question regarding its operation.
If we go away for the weekend, I set the thermostat at 55 degrees.
When I return home, I raise the setting to 68 degrees.
The furnace will kick on.
But, it doesn't run constantly until it has reached 68 degrees.
Meaning it will run for a while, then kick off for a few minutes or so, then kick back on.
So, my question is this:
When the furnace is trying to get to the set temperature, should it run constantly until it gets to the set temperature or is it normal for the unit to cycle on/off occasionally as it is trying to reach the desired temperature?
Thanks.
mike
Thanks.
mike
