Kelly Holmberg
I have a daughter with special needs for whom I have built a tub that is about waist high so we can stand to give her a bath. Facing the tub on the left (foot end) is a pop-up stopper. The tub then slopes up to the right (head end), which is about 5 inches higher than the foot end. The drain goes to a p-trap, then to a double sanitary T with a clean out on top. The over flow at the head goes to the other side of the double sanitary T. The double sanitary T then connects via a 90 degree elbow to a sanitary T in the vertical vent and down to the rest of the drain system in the ceiling of the basement.
My question, after all that, is with regards to the venting and gases that may work their way to the overflow (since there is no p-trap). I was going to put a second p-trap between the double sanitary T and the over flow, but given this will rarely have water in the over flow, is this an acceptable method or the proper way to do this?
Thanks for you help and guidance.
