Question on installing a tub
Discussion in 'Shower & Bathtub Forum & Blog' started by BlackNoir, Mar 13, 2009.
  1. BlackNoir
    BlackNoir Software Engineer
    Mar 13, 2009
    Software Engineer
    Centerville, MN
    I'm putting a drop-in tub in a remodeled bathroom. The drain and water supply lines will be new. The problem is I have no access to directly under the tub once it's in so how do I connect it with the drain?
    The layout is thus. The bathroom is on the second floor and I have access to the space between floors so I can run the drain pipe and supply pipes through it to a spot under the tub. I can then cut a hole in the floor, where the tub will be, and strap the tube to subfloor and cement on a 90 or a trap. At this point if I drop the tub in I have no way to by-hand connect the tub to the new drain.. what do the pros do here?
    The supply should be easier because the drop-in tub sits in a frame which won't be enclosed yet so I can make those connections.
    Thanks for ANY Advice,
    BlackNoir
  2. BlackNoir
    Mar 13, 2009
    Software Engineer
    Centerville, MN
    I think I just found the answer. I don't have the tub yet, going to go look at one tomorrow, but is it common for the drain for the tub to go directly into a horizontal pipe which runs along the bottom of the tub and connects to the overflow, thus putting the drain pipe on the side of the tub instead of under it? I thought the drain would go straight down and thus be surrounded by a mortar bed but if not I can just get to it via the access panel for my supply lines!
    Please tell me this is the common technique.. :)
  4. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    It is and make sure your tub drain connects to the overflow before the p-trap.
Similar Threads: Question installing
Shower & Bathtub Forum & Blog Demo'd Fiberglass Shower & Installing New Tile Shower But I Have Questions??? Saturday at 2:13 PM
Shower & Bathtub Forum & Blog Installing Sterling Ensemble shower and drain question Jun 20, 2013
Shower & Bathtub Forum & Blog Question on installing a Signa Jacuzzi Soaker Tub Jan 17, 2011
Shower & Bathtub Forum & Blog Installing Hot Soak Tub - access panel questions Jan 16, 2011
Shower & Bathtub Forum & Blog Question on installing tub drain kit Feb 23, 2010
