Question on installation methods regarding pressure and volume/
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by joebartolucci, Mar 14, 2009.
  1. joebartolucci
    joebartolucci In the Trades
    Feb 27, 2009
    Operations Supervisor for a local wate company and
    North East PA / New Jersey
    I have a question regarding increasing water volume in a residential plumbing installation.
    My situation.
    I am plumbing 2 bathrooms, the master bath (9 Cold FU, 60' from source and 6 Hot FU, 20' from source) and the second floor bath (7 Cold FU and 4 Hot FU, same distance from source.) 46 to 60 psi.
    The shower in the master bath is on the same wall as the toilet and double sinks for the second floor bath. I was going to feed both bathrooms with a 1" for the cold water and 3/4" for the hot water wich according to the code is okay however I am worried about two possible problems.
    1. I think there will be a major pressure drop once the water is on for say the shower and someone flushes the toilet.
    2. The hot water will need to run for a while before the hot water reaches any of these baths.
    So here is what I am thinking of doing and please let me know if you are in agreement.
    For the pressure drop I was going to run a 1" pipe for each bathroom's cold water and a 3/4" pipe for each bathroom's hot water. Possibly use 1-1/4" pipe as a header and feed the fixtures off this header with 1/2".
    For the hot water I am thinking of tying in the farthest hot water pipe to a gravity loop system back to the hot water heater's drain valve port. This should at least keep the hot water flowing to minimize time.
    Your help is most appreciated and I thank you in advance.
    Joe
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    The pressure will be the same no matter the size of pipe.
    larger pipe more volume.Pressure remains the same.
    Then you have static pressure and working pressure.
    60psi when all fixtures are closed is static pressure.
    40 or less is working pressure would be when a fixture is open.
    this is just an example.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You may want to consider a recirculation pump for the hot water. This would give you instant hot water at all locations. You need to understand the difference between pressure and volume. While there is a relationship, they are not the same. You may be on the right track with increasing pipe size, but you are going overboard on sizing. There are charts available to help you with this.
  5. jimbo
    jimbo Plumber
    Certainly no need for anything larger than 1" in your picture.
    And while larger pipes minimize pressure drop problems, a larger hot pipe means it will take even longer to purge the cold and get hot water to the fixtures. Recirculation will fix this. Gravity recirc is good. The return line must run continously up hill....no dips or humps.
  6. hj
    pipes
    An downhill once it reaches the far end of the system, again without any dips or rises. There is a point at which it makes no difference how much larger you make the pipes, it will not have any effect on the dynamic pressure or volume. That point is when the maximum flow is passing through the small openings in the faucet's seats. 1" pipe might even be too large to make a difference. In addition, you MUST use a pressure balancing shower/tub valve so the effect of slightly undersized pipes would be minimized and unnoticeable.
Similar Threads: Question installation
Plumbing Forum, Professional & DIY Advice Delta Tub Spout Installation Questions Jan 10, 2017
Plumbing Forum, Professional & DIY Advice Steam generator installation question Dec 28, 2016
Plumbing Forum, Professional & DIY Advice Kohler Veil Installation Questions and Tips Jan 6, 2015
Plumbing Forum, Professional & DIY Advice Question on toekick installation to tee or not to tee? Feb 28, 2014
Plumbing Forum, Professional & DIY Advice 3 questions regarding installation of a replacement assembly to stop a Jacuzzi leak. Dec 12, 2013
