Question on how I've looped the PEX lines
ChasB
Renton, Washington
I've got my rough-in inspection for a bathroom on Tuesday. I'm wondering about how I've done the supply lines. I used rigid 3/4 pex to bring the water to the bathroom, then switched to 1/2 pex and did the loops you can see under the floor up to the sink and toilet. I read that loops or something similar should be used due to pex expansion but I'm wondering if what I have done here is overkill or unnecessary. I used 1/2 inch rigid pex up to the shower valve so no loops for those.
http://imgur.com/ijhC6gx
http://imgur.com/thxVcDH
I would wonder if you would get dinged for not having enough supports.
ChasB
Renton, Washington
Hard to see in the pic but I did clamp the loops to the boards on the wall. Might be more than 32 inches from those to the 90 degree bends, so I will check that, if that's what you're referring to. Actually I'm sure it's more than 32 for the sink lines. I can address that if I leave the loops.
I was looking at the loops, plus the lines up to the shower stood out to me.
years ago a customer installed his own heating system using "loops" like those. When we redid the system we had a whole lot of extra copper tubing in our scrap bin. There is absolutely NO REASON for the loops. The inspector might laugh at the installation, but will probably pass it.
ChasB
Renton, Washington
We'll see I guess. He's coming over within the next couple hours so too late to mess with it now! ;-)
Thanks for the post. Maybe I'll ask him if I can remove them.
ChasB
Renton, Washington
He said the loops were not necessary, but he failed me for how I did the horizontal wet vent for the toilet, so I've got work to do. Hopefully be ready for another shot next week. Thanks all for the comments.
