Question: Geothermal Vertical Closed Loop
Steve2278
North Carolina
I'm building a new home on my existing property and I've been researching a number of different heating/cooling options and I find geothermal to be particularly appealing. Unfortunately the installation cost appears to be quite high when factoring-in the cost of the pump, piping and excavation etc. However, I got some very encouraging news today from a an experienced well driller who gave me an estimate on drilling a new well, as my existing well is rather shallow and picks-up a lot of sediment.
He gave me a price for drilling a new well, and he said if he got the job (and since he would have his drill rig set-up on the property) he would drill 3 seperate holes 120' deep for the geothermal system at a cost of $500.00 per hole. Great price in my opinion! Unfortunately the well contractor does not install the geothermal piping and I guess my question is "does the piping have to be installed at the time the holes are drilled?"
I have not yet selected a contractor for the geothermal system and I don't know if I need to do so at this point?
Geothermal contractors have a very specialized niche' trade and these guys have the right to make a buck just like everyone else and I respect that. At the same time, I'm a guy who's trying to save some money where ever I can and I want to minimize my expenses as much as possible. I came across a number of geothermal heat pumps after researching retailers and I can purchase a 3-ton geothermal heat pump for about $3,500.00. That being said, I can have the holes for the vertical loop system drilled for about $1,500 and I can purchase a pump for about $3,500, that leaves the installation and HVAC work remaining and I'd like to hire a contractor do just that portion of work specifically. I'm not sure if they would be willing to?...but I hope I can find a couple guys who would be interested in working in this capacity.
The problem is that most contractors want to take-on the entire job, however, I'd prefer to purchase the unit and drill the holes for the loops myself to save on installation costs. I'm just not sure if most contractors would be willing to work in this capacity and I'm not sure at which point to involve them and to what degree?
Any advice on how I need to proceed from here would be greatly appreciated.
Thanks in advance!
Steve
Gator37
Retired prof. engr.
Alabama
If you are "not" asking a contractor to take the responsibility for system performance or warranty issues you should be able to get a contractor (or skilled labor) just to install the system per your instructions (and your design) . There are issues that you should review prior to starting, such as soil type for heat dissipation, well number and depth, piping material, piping layout (reverse return, etc) leak test of piping, physical installation of pipe (since the piping can come on a roll with no joints other than the U bend at the bottom of the well), grouting of the holes and grouting material (very important after the piping test is performed (and passed)), filling and air purge of the piping, is the circulating pump included in the purchase of the heat pump (?) big enough to overcome the friction loss due to elbows, fittings, valves and heat exchanger pressure drops, who is going to wire it (power and control).
If the system does not perform you cannot expect the contractor to take the responsibility of the system installation that was initiated per your design and/or directions.
Most of their profit is from the purchase and resale of equipment the rest is typically labor with a little MU. (They have to eat also.)
If you are sure that you can provide all the answers for your design, I would hire skilled labor to install the piping and HVAC unit per your instructions and hire a contractor to wire the unit and start it up.
gdgraham
Geothermal Installer
Ontario, Canada
www.headwatersgeothermal.com
I agree with gator regarding a contractors willingness to take on your job. Sounds like not much profit an lots of risk for the contractor. I don't think you mentioned where you are located?
Do you have enough land for a horizontal loop? We typically install one 600 foot roll of 3/4" pipe per ton of equipment. At a depth of 5-6 feet. Just a thought.
Brokersdad
canada
What company do you sell for gdgraham?
kyleanderson
manchester, kentucky
So you have found your pump for 3500.00 and driller for 1500.00. and looking for skilled company for $????????????? good luck you gonna need it. Im in Ky and the pump cost is less that 3500.00 and we use a company for drilling holes at $3. per foot,but he allso supply the loop with header. all we have to do is hook up loop from header to unit pumps supply and return that is. Three ton geo here range from $13,000.00 up to $30,000.00 with all the bells and buttons, it ranges with what you want with system. So with a range of $13,000.00 system and you spending $5,000.00 with briller and pump there is another $8,000.00 on table here. No skilled company here would even talk to you about this job. We stand behind our work and for someone to design a loop and cut corners and it can happen, the pump will know it first and then the owner and then the owner call the man who installed the pump. I dont see the loop man taking any blame for what is 120 feet in a hole cover up with another 5 feet of soil, but the skilled geo man with simple test will know, and the ball is now the owner hands, who do you trust. the geo man that the look man is blaming, or the loop man that the geo man who blames the loop man. This isnt good for a skilled company or the owner. find a trusted company to install you system. dont buy nothing, just pay the man and let him do the job. there are two companies here that know geo, and the rest are lost. howmany know geo around your town? I have and still can make a great living going behind air to air installer who dont know geo. good luck
