Question for Ba9s LED Bulb
Discussion in 'Electrical Forum discussion & Blog' started by nicho, Sep 20, 2012.
  1. nicho
    nicho New Member
    Jul 25, 2012
    china
    Hi all,
    I have a LED bulb Ba9S type (130V) which has internally an array of 7 LEDS.
    All the datasheet mention is Voltage:130V AC/DC +10%, Max Current:5,9mA Colour:White clear
    In my circuit the bub is connected directly to a 110V battery and I am trying to add an external resistor to reduce the current into the bulb but before I do that, I would like to figure out the following:
    the array of 7 LEDs in a single bulb are connected in series or parallel?
    The 5.9mA refers to the current of the single LED of the whole array (if in parallel)?
    Can I assume the internal resistor is 21.47kOhm (parallel case, with 3.3V on each diode) or 18.12kOhm (series case)?
  2. jimbo
    jimbo Plumber
    Backwards logic. The buls system is rated to operate on 130 volts. You have 110 volts which means you might get 8% less light output than design. WHY would you put a resistor in series or parallel with that to further reduce the voltage and current to the bulb.??
  4. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    I am sitting on the edge of my chair waiting for the answer to that Jimbo. Thats a pretty small bulb package
    http://www.bulbtown.com/Miniature_Bayonet_Base_BA9S_s/322.htmtting
    :p
  5. nicho
    nicho New Member
    Jul 25, 2012
    china
    OK, thanks, just a experiment:D
  6. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    In your opinion is this spam?
  7. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Seems a little odd for someone that Advertizes Led Lighting.
  8. BobL43
    Mar 25, 2011
    Long Island, NY
    I don't know. It did not cause me to click on the link to whatever nicho posted. My link was gotten from a quick googling for BA9S 115 volt LED bulbs
  9. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    More on a answer to the question on operating LEDs at a higher voltage, They should be in series, and matched very close.
    Many LEDs have a built in resistor, and if they don't it would be kind of silly to use 1 per LED when 1 can be used for all of them if the LEDs are in series.
    LEDs normally short when they burn out, so the remaining ones would have a higher voltage.
    If to many of them short then the resistor may open or the fuse link will open.
    As far as I know a BA9S is the type of bulb base , not a type of bulb.
    I want a 120V battery to experiment with.
  10. BobL43
    Mar 25, 2011
    Long Island, NY
    Yah, it is a mini bayonett basse bulb like the good ol' 47 was it?
    use 9v batteries in series or the one from your Prius (nope that is over 200 volts) or steal 10 regular car batteries
  11. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I think the 47 and 51 were the most popular in the day.
    I would be afraid of using that base for 110 because it seems that it could arc over.
    But I think some bulbs with that base go to 220V.
    I guess times are a changing.
    Electricity must be getting safer.
  12. BobL43
    Mar 25, 2011
    Long Island, NY
    that's b'cause of all those codes and rules make it that way. rules is rules
  13. hj
    quote; that's b'cause of all those codes and rules make it that way. rules is rules
    And then there are the rednecks who say, "Rules? We don't need no stinkin' rules". Or the DIYer who says, "I want to do it this way. Will someone please tell me it is okay to do it, because I will probably do it anyway".
Similar Threads: Question Ba9s
Electrical Forum discussion & Blog Question on 3-wire Kitchen Range > 4 wire Nov 24, 2016
Electrical Forum discussion & Blog Question about Ceiling Fan wiring Nov 9, 2016
Electrical Forum discussion & Blog Another question: generator power necessary for 1/2 hp pump jet pump Oct 8, 2016
Electrical Forum discussion & Blog Quick electrical question Aug 31, 2016
Electrical Forum discussion & Blog Bathroom remodel code question Jun 7, 2016
