Question about the slope of a 3" line...
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Southpaw134, Feb 3, 2009.
  1. Southpaw134
    Southpaw134 New Member
    Jan 26, 2009
    Workforce Management Analyst
    Florida
    is there such a thing as over sloping (too extreme of an angle) an outdoor 3" sewerline?
    I assume there isn't, I assume there are some sewer lines that run vertical..., but assuming is, an, umm...big assumption.
    Also, if I have a vertical line that I need to connect to a horizontal line is there a minimum or mximum angle of connection between the two (i.e., 45 or 90 degrees)?
    Thanks in advance.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    1/4" per foot is a minimum pitch.
    The old liquids outrunning the solids is a myth that has been busted.
  4. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    As far as I know, there is nothing such as oversloping, unless your talking about a p-trap in proximity to a vent.
    The minimum slope between 2 connections is 1/4" per ft or 2% there is no maximum
  5. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Really¿ So we just do it because it's code¿
  6. Redwood
    Dec 15, 2007
    Service Plumber
    If you read your code chances are it states that it is a minimum pitch...
  7. Southpaw134
    Jan 26, 2009
    Florida
    Thanks for the replies.
  8. kingsotall
    Aug 17, 2008
    I always saw the validity in the liquids outrunning the solids.
  9. Redwood
    Dec 15, 2007
    Service Plumber
    Liquids will always outrun the solids. If you flush a toilet with a wad of toilet paper in it do you think that it gets to the city sewer on on flush?
    Not a chance!
    Infact a sewer relies heavily on other flows to clear the line.
  10. tjbaudio
    tjbaudio Sound and Light Suppervisor for a School District
    Dec 6, 2005
    sound and light suppervisor for a school district
    Wisconsin
    That is one reason the shower is near the end of the line in my house, right after the toilet.
  11. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    If there were maximum pitch rules then you couldn't run a vertical stack :D
    Sewage systems are designed to move waste at 2 feet per second.
  12. C NUMB
    C NUMB Plumbing Contractor
    Jan 13, 2009
    plumber
    NPR, FL
    In your location it is what Redwood said 1/4" per ft. On the vertical to horizontal use either 2 45's or a long sweep 90.
  13. quinocampa
    quinocampa Mechanical engineer in marketing. Uhuh.
    Jan 20, 2009
    Indianapolis
    I've inspected all of my drain pipes in the crawlspace. My home is only 20 years old, and the entire drainage system is basically flat. The new lines I'm installing are sloped properly, but I wonder why it was done this way. During my bathroom remodel, I've also found a hard vent duct that was crushed to go over the top of a shower drain in a 2nd floor joist bay, soft HVAC ducts in the crawlspace draped over joists 'til they're choked off, and two bathroom fans with no exhaust ducting attached. One of them was blowing directly into insulation, which was right on top of the fan. I've corrected all of these shortcuts. I will defend my right as a homeowner to do my own work when this quality of work is the alternative. Don't even get me started about last year's contracted attic remodeling.
  14. Southpaw134
    Jan 26, 2009
    Florida
    Thanks again for all of the help and information.
  15. kingsotall
    Aug 17, 2008
    Guess this greenhorn has a lot to learn! Thanks for the insight fellas.
  16. hj
    offset
    There is no "code" requirement as to how you make a change in elevation, but the prudent way is to make the transition as smooth as possible. If you have room the best way is to just deflect the pipe, the next best is two 22 1/2 bends, or move on to using two 45's, and if there is not enough space for that, then two 90's is the last option.
  17. Redwood
    Dec 15, 2007
    Service Plumber
  18. Southpaw134
    Jan 26, 2009
    Florida
    Thanks Redwood, that was a good read.
  19. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    So you'd want the catchers mitt before the bucket. :D
    In a vertical stack the water actually clings to the inside of the pipe and swirls it's way to the bottom. The center is mostly empty.
  20. hj
    drains
    Which is why they make "anti vortex" roof drains so the pipe WILL be full and thus can be made smaller.
  21. rmelo99
    rmelo99 Network Engineer
    Jul 7, 2006
    Network Engineer
    Good reading, thanks
Similar Threads: Question slope
Plumbing Forum, Professional & DIY Advice Quick toilet drain slope question Aug 24, 2015
Plumbing Forum, Professional & DIY Advice question about slope Mar 22, 2014
Plumbing Forum, Professional & DIY Advice New project questions - Water testing and restricted slopes Jan 14, 2013
Plumbing Forum, Professional & DIY Advice Venting/drain slope question Jun 17, 2005
Plumbing Forum, Professional & DIY Advice 1950 Renovation Questions Yesterday at 10:06 PM
