Question about tamper-resistant outlets
Khayes
Alpharetta, GA.
Hi - we have purchased a 2-year-old home which has all TR outlets. I assume this is code now. Inserting plugs is challenging but we've gotten the hang of it. Problem is several of the outlets won't keep the plug once it's inserted. The slightest pressure disconnects it, sometimes even the weight of the cord will disconnect it. Is this just a matter of cheap builder-grade receptacles? Would upgrading to a more expensive receptacle help? Or is this just the way it is with the new requirements?
Ken
Yes. Yes.
Consider plugging and unplugging some plugs in different outlets at the store.
Chuck Shaughnessy
Virginia
Eepla
Ken[/QUOTE
Ken
Replace them. I have replaced nearly all of mine recently. Usually w heavy duty plugs. Good deals online and much better quality. And yes TR is now code.
It's probably the builder-grade receptacles, but also keep in mind that repeated use of high-powered loads, especially if they are used for extended amount of time, can cause heat, and that can cause the spring temper on the socket to get weak, and the plug get loose. A loose plug itself just makes it worse, since it adds some resistance, and thus more heat.
Cacher_Chick
Test, Don't Guess!
There are a lot of junk receptacles and switches in the stores now. Buying the commercial grade products has given me better results, but you will pay for that quality.
Khayes
Alpharetta, GA.
Thanks again everyone. Yes, I know the prices vary greatly. I think I'll replace one outlet with a commercial grade one and see if it makes a difference before investing in many more.
