Question about moving stove line to dryer.
Discussion in 'Electrical Forum discussion & Blog' started by enviroko, Aug 25, 2007.
  1. enviroko
    enviroko New Member
    Apr 2, 2007
    We currently have an electric stove and a gas dryer but we are in the process of installing a gas stove and electric dryer. Here is our situation...
    The hot wire that feeds the stove looks like it says 8/3 (old and hard to read).
    The hot wire first connects to a junction box then out to the stove with a 6/3 wire.
    There is already a 10/3 wire ran to the dryer that was disconnected by someone prior to me buying the house.
    Question: Can I disconnect the old hot (8/3) from the junction box and connect that to the 10/3 wire to feed the dryer?
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Yes but be sure to change the breaker to a 30
  4. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    you need to have a professianal plumber check out your gas switch over
    a gas dryer is rated at 38,000 btu's a full size gas range is rated at 65,000 btu's gas is "NOT" sized to pressure, but to volume not the right size gas line means you will be sterving a gas appliance some where in the house "which"
    could cause a "CARBON MOXIDE"!!! problem down the road when the furnice and stove, and
    water heater is all running at the same time!!:( :(
    like when you have the whole family over for thinksgiving, or christmas
    JERRYMAC MASTERPLUMBER:)
  5. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Also gas stoves require 3/4 pipe to operate properly.
  6. enviroko
    enviroko New Member
    Apr 2, 2007
    Unfortunately I still have a fuse box (changing within six months hopefully) and I was unable to find a 30 amp to fit. 35 was the closest. The fuse that was used for the stove was a NON-45 class K5. Can that be replaced with a 30 amp fuse?
    I do have 3/4" pipe going all the way to the flex line of the stove but sounds like that doesn't guarantee 65,000 btu's. Is that correct?
Similar Threads: Question moving
Electrical Forum discussion & Blog moving breakers and a power source question Jan 9, 2009
Electrical Forum discussion & Blog Question on 3-wire Kitchen Range > 4 wire Nov 24, 2016
Electrical Forum discussion & Blog Question about Ceiling Fan wiring Nov 9, 2016
Electrical Forum discussion & Blog Another question: generator power necessary for 1/2 hp pump jet pump Oct 8, 2016
Electrical Forum discussion & Blog Quick electrical question Aug 31, 2016
