Question about CPVC reliability
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Otis, Jan 5, 2010.
  1. Otis
    Otis New Member
    Jan 5, 2010
    Southeast
    Greetings all,
    Brand new here. I've roughed in some plumbing for my bathroom remodel and I decided to use the CPVC dogears at the fixture locations. These are the ones sold by Lowes & HD that have a brass threaded insert for the stub out, but CPVC on the remaining portion of the fitting...including the plastic mounting ears. One person told me that the plastic ears were prone to break, while another guy told me he's used them many times with no problem. This plumbing will be run through the interior walls. I chose CPVC for that reason. I feel better about using glued joints behind the drywall. I'd welcome any warnings or assurances about this strategy. Thanks in advance for any responses.
    Michael
  2. Terry
    Aug 17, 2004
    You should be fine.
    I noticed plenty of homes here have been run with CPVC.
    I lean more towards PEX and copper.
  4. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    CPVC is very common down here.
  5. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    What we are starting to see is the hot water lines are getting brittle, to the point when making repairs on hot water lines we can not use cutters as the pipe shatters. Down here there using it under slabs. According to the leak detection company's they are also starting to see failures in hot water lines. I think PEX is the better choice.
    John
  6. dargo
    dargo New Member
    Jan 9, 2010
    MA
    I also live down south and all the homes in Texas (near houston) have been using PVC (not CPVC) for cold water lines for 15+ years. Copper is not used much, only on hot.
  7. Terry
    Aug 17, 2004
    PVC isn't allowed for indoor use.
    Only CPVC
  8. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    I really can't stand underslab lines....
    How old are the brittle ones?
  9. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    I haven't seen any under slab CPVC leaks myself, I'm going by what the leak detection companies are saying. What I have seen is is hot water lines 4yrs old getting very brittle. The worst was a recirculating line. It was a extreme case because it was recirculating 24-7.
    John
  10. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    My house is over 10 years old now and no problems so far. Cape Coral banned copper (I don't know if it's still the case) in residential due to leaks. 10-15 years was normal for copper and then you were on borrowed time.
  11. hj
    At one time they did not recommend CPVC for hot water systems with a circulation system. The constant hot water was detrimental to it. If you intended to use CPVC, they recommended capping off the circulation line.
  12. dargo
    dargo New Member
    Jan 9, 2010
    MA
    Could very well be in your area but not in well-known cities in Texas. Not starting anything but I know what I see when I go in my attic to look at the furance(s), water tank etc.
    when I had the inspection I asked the inspector and this was the norm..
Similar Threads: Question CPVC
Plumbing Forum, Professional & DIY Advice CPVC Coupling Question Jul 10, 2014
Plumbing Forum, Professional & DIY Advice sagging cpvc line and UV question Jan 10, 2011
Plumbing Forum, Professional & DIY Advice Insulating CPVC Plumbing Pipes and PEX Questions Dec 8, 2010
Plumbing Forum, Professional & DIY Advice Question about copper/CPVC union May 21, 2008
Plumbing Forum, Professional & DIY Advice CPVC Question Jan 10, 2008
