Question About Clean Out Caps...
Discussion in 'Drain Cleaning' started by Mozart, Nov 29, 2010.
  1. Mozart
    Mozart New Member
    Nov 29, 2010
    cHICAGO
    Hi guys, I'm new to this board & hope to learn some tips from reading the posts. I'm a real estate (small time) investor & contractor in Chicago. I'm not a plumber but I know how to do most basic plumbing stuff & find I'm doing more all the time. If I can't handle it I call my pro. Sometimes I run into things I don't understand & hoping I can get some help here
    OK, here's my problem...
    I'm cleaning out the pipes under a basement utility sink. I went to open the clean out in the stack & found the cap just nudged in tight enough to keep any water from leaking out. In other words, the cap has threads but the stack hole does not. There's no way to screw it in tight. I guess the last person working on it just smacked it with a hammer until it was tight enough not to leak. Obviously, I don't want to leave it like that
    I've never seen something like this. I figured all the female openings in a clean out would have threads. This one is totally smooth. I'm perplexed
    Is there a special type cap to use? By the way, it's all steel (or cast iron)
    Thanks in advance
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    They make a twist-in expanding cap that will suffice in this situation. Old threads have a tendency to disappear/disintegrate over time.
  4. Mozart
    Mozart New Member
    Nov 29, 2010
    cHICAGO
    Thanks for the reply
    Do they sell these caps at Home Depot type stores or do I need to go to a plumbing supply place?
  5. AssTyme
    AssTyme Plumber
    May 27, 2010
    Wisconsin
    Most hardware stores, Home Depot, etc... will have them.
  6. hj
    Measure the inside of the opening. Yours may be 4". Most of those plugs are meant to fit inside a pipe, not a fitting, so you may not find one that will expand enough to seal your opening.
Similar Threads: Question Clean
Drain Cleaning Questions to ask a drain cleaning company - regarding old pipes Dec 30, 2015
Drain Cleaning Question about new clean out installation Jul 29, 2013
Drain Cleaning Raised head Clean-out plug removal Question Jan 14, 2013
Drain Cleaning No-hub coupling questions Jan 30, 2017
Drain Cleaning Jetting 8" PVC w/ a 3000 psi 4.0 gpm washer? Homeowner questions... Jul 14, 2013
