Question about 3/4 S-Trap
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by iminaquagmire, Mar 15, 2009.
  1. iminaquagmire
    iminaquagmire DIY Senior Member
    Dec 16, 2007
    FF/EMT
    Would this be one? The trap would be that of a 2nd floor shower. The top outlet of the santee would tie into the stack vent in the attic, the bottom into a 90, then run parallel to the joists to the stack ~4 feet away. I know it would be if it downturned directly after the trap outlet, but ~24" away?
    [​IMG]
  2. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Yes, you would need to vent before the offest.
  4. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    What software did you use iminaquagmire¿
  5. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Me too I use sketchup but havn`t mastered it yet.
  6. SewerRatz
    Nov 20, 2008
    Chicago, IL
    I too would like to know which software.
  7. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Any time the trap weir is above the trap arm inlet you have the possibility if creating a siphon. I've never been quite wure who coined the term 3/4 S trap and stuck it to just about any non compliant Trap arrangement. True 3/4 S traps were a cast iron fitting.
  8. iminaquagmire
    Dec 16, 2007
    FF/EMT
    Thanks for the help. Looks like I'll have to figure out another way to do this. I'm trying to raise the trap outlet so that I can fit a can light under the trap for the shower below. The reason it can't go up higher is that the santee pictured in the model doesn't actually exist, instead there is a double fixture fitting for the drain for the bathtub which can't be moved. I just didn't want to take the time to model the other drain.
    I made that in Google Sketchup 6. I haven't tried Sketchup 7 yet but it looks nicer. Both are free but you can buy a pro version for $95. The pro version would be overkill for me, but it may be justifiable for pitching proposal to clients for pros.
    Its really easy to learn and there are many "components" such as sinks and cabinets and fixtures that can be downloaded. I don't know how good it would be for pipes, as its kind of difficult to rotate and line up fittings, but for layout and design its great.
  9. hj
    3/4 s
    . A true "S" trap discharges vertically. A "P" trap discharges horizontally, and can be considered a half "S" trap. Discharging at an angle between the two, creates a 45 degree angle which is intermediate between a full and a half so it becomes a 3/4 "S" trap.
  10. kingsotall
    Aug 17, 2008
    Nice. I'm still learning how to plan layouts isometrically. I'll stick with my 30/60 right triangle for now.
Similar Threads: Question S-Trap
Plumbing Forum, Professional & DIY Advice Not your usual S-trap question Apr 6, 2011
Plumbing Forum, Professional & DIY Advice p-trap or modified s-trap question Mar 1, 2007
Plumbing Forum, Professional & DIY Advice Water supply and meter question Tuesday at 7:46 AM
Plumbing Forum, Professional & DIY Advice Compression valve questions Monday at 8:57 PM
Plumbing Forum, Professional & DIY Advice Back to back second floor bathroom DWV questions Sunday at 12:03 PM
