Quarter-turn valve
Discussion in 'Toilet Forum discussions' started by SamC, Aug 10, 2012.
  1. SamC
    SamC Member
    Apr 12, 2007
    Georgia
    I have read posts recommending replacing the usual multi-turn inlet valves on toilets with quarter-turn valves, since the valve is always fully-open or fully-closed. Is there a sealing advantage to the ball valve used in the quarter-turn models? Would it also be worthwhile to replace the same valves on all the sinks?
  2. jadnashua
    When remodeling (or new), my preference is to use 1/4-turn, ball valves. On a conventional stop, the rubber washer can become hard and brittle so when you turn it off after not being touched for maybe decades, it can break apart, and never seal when you need it. A ball valve usually works more reliably. I probably wouldn't just decide to replace what was there unless I was swapping out say the faucet or changing the toilet, or, obviously, if I needed to do some repair, and the existing valve didn't shut off. It's much nicer to not have to turn the water to the house off when doing a repair, course, that main shutoff may no longer work, either!
Similar Threads: Quarter-turn valve
Toilet Forum discussions Kohler K-3406 San Miguel Toilet fill valve . . . Feb 1, 2017
Toilet Forum discussions Whose idea was this FlowTite valve? Jan 21, 2017
Toilet Forum discussions Intermittent hissing noise from Toto fill valve even after replacements Jan 11, 2017
Toilet Forum discussions Champion Max 4 - Fill Valve Issue Dec 21, 2016
Toilet Forum discussions Flush Valve Issue? Dec 10, 2016
