Quarter turn plug
Discussion in 'Shower & Bathtub Forum & Blog' started by SamC, Feb 13, 2008.
  1. SamC
    SamC Member
    Apr 12, 2007
    Georgia
    I have one of those drain plugs in my tub that is attached to the drain. A quarter turn lets it drop down to plug the drain. The drain gets loaded up with hair from time to time. Is there a way to get that plug off to clean out the drain?
  2. jimbo
    jimbo Plumber
    It unscrews. On some, there is a setscrew on the little knob. On others, you put it down to the "closed" position, then turn the know CCW to unscrew.
  4. hj
    plug
    Most are removable once you unscrew the lift knob from the plug. But others have setscrews that are almost, if not completely, inaccessible making removal very difficult.
  5. SamC
    SamC Member
    Apr 12, 2007
    Georgia
    Thanks much. It had a Phillips head screw, just visible under the rim. With the plug removed I was able to quickly clear the drain of hair and soap buildup with a pair of needle-nose pliers. Thanks again.
Similar Threads: Quarter turn
Shower & Bathtub Forum & Blog Upgrading shower stems from compression to quarter-turns May 9, 2015
Shower & Bathtub Forum & Blog Moen Posi-Temp Banbury Model One Handle Tub/Shower Faucet - New install, hard to turn Feb 1, 2016
Shower & Bathtub Forum & Blog Sound of running water after shower faucet is turned off? Jan 11, 2016
Shower & Bathtub Forum & Blog Three Handle Diverter - Changing Shower/Tub Diverter Turn Direction Dec 26, 2015
Shower & Bathtub Forum & Blog Shower Handle Doesn't Turn + No Hot Water Dec 24, 2015
