Quality multi-function handheld showerhead with pause function
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by NikiLC, Apr 11, 2014.
  1. NikiLC
    NikiLC New Member
    Apr 11, 2014
    California
    Hello all,
    I may be asking for the impossible, but... I am looking for the "perfect" handheld showerhead & would appreciate your thoughts & advice.
    These are the characteristics I am hoping for in a handheld:
    * Multi-function that would include a massaging function and also a directed/focused spray that would be good for washing dogs.
    * The ability to temporarily pause the spray from the showerhead - for soaping the kid, dog, etc.
    * High quality, but light enough to be functional when using as a handheld.
    * The shape of the handle is comfortable to hold for small to large hands.
    * The head itself is not so large/heavy/unbalanced as to make it unwieldy.
    * Low water usage but strong flow.
    * Comes in brushed nickel that does not have a slight yellowish tint (to me Delta & Hansgrohe's brushed/satin nickel are on the "warmer"/yellowish end of the spectrum).
    Thoughts & recommendations?
    Thanks in advance!
  2. hj
    #2 would normally be a no-no, because a "pause" could turn in to a full time shut off which would cause all kinds of problems elsewhere in the plumbing system. Some of the other requirements are contradictory.
  4. NikiLC
    NikiLC New Member
    Apr 11, 2014
    California
    Sorry, I don't think I used the right terminology with the word pause. I am glad there are folks who do, but I don't understand the technical aspects at all.
    I did do more research and found there is an American with Disabilities Act guideline that "to be ADA accessible, hand-held showers should include a non-positive shut-off control which turns off the flow of water using a control on the actual hand—held shower". So far I found the Kohler Forte hand held meets the guideline.
    It's not surprising that some items on my perfect handheld wishlist are contradictory - what can I say, I want it all. :} Could you help me out in understanding the ones that I should give up on?
    Thanks!!
  5. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    Yep Kohler Forte 10286, but it doesn't come in the color you want.
    Also K-10343 comes in brushed nickel.
    I think there is a lot of confusion on amateur and DIY sites about what 'non positive" means in this context.
  6. NikiLC
    NikiLC New Member
    Apr 11, 2014
    California
    Thanks. I will check it out.
  7. NikiLC
    NikiLC New Member
    Apr 11, 2014
    California
    WJCandee, I should have asked - can you clarify what non-positive means for this situation?
    Thanks again.
Similar Threads: Quality multi-function
Plumbing Forum, Professional & DIY Advice Plumbers: Which kitchen faucet brands are tops in quality/reliability? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Clawfoot drain / overflow quality Oct 19, 2016
Plumbing Forum, Professional & DIY Advice Recommendations for a good quality faucet? Jan 9, 2016
Plumbing Forum, Professional & DIY Advice Quality PEX valve? Dec 21, 2015
Plumbing Forum, Professional & DIY Advice What are the best quality braided SS faucet supply lines? Dec 1, 2015
