PVC Wall Tube Connection
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by BillM, Mar 14, 2009.
  1. BillM
    BillM New Member
    May 28, 2007
    Michigan
    Hello all.....
    Please bear with me, but I've got a very basic question......
    I have 1-1/2 inch PCV Wall Tube from behind vanity. I am trying to connect Plastic P-Trap to the PVC. The PVC has no threads......just straight PVC coming out of wall.
    What is best way to attach connector? 1-1/2 inch connector doesn't seem to fit correctly? Is the term "Desanki" familiar? Local plumbing supplier told me that I "cut off the Desanki", when I shortened the wall pipe......so now attempting to reconnect, but standard HD plastic doesn't seem to be a 'tight' fit? Don't want a leak problem later?
    What am I doing wrong?
    Thanks for info...
    -Bill
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I'm just a DIYer, so admittedly there are lots of things I don't know, but I have no idea what a "Desanki" is, Google doesn't either. But, to transition from PVC pipe to a P trap, you need a threaded adapter. Smock man at HD didn't give you very good advice. You would be wise to have someone illustrate how to make this connection with actually pieces of pipe and fittings.
  4. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    It is called a desanko or trap adapter.The term desanko comes from the man that invented it.It was his name.
  5. BillM
    BillM New Member
    May 28, 2007
    Michigan
    Thank you......I'm just back from HD......
    Gary....you were right.....Smock Man did steer me wrong.....
    cwhyu2......thanks for clarifying 'Desanko'.......
    Bottom line - Desanko=Trap Adapter.....and that's what I ended up with......finally......
    Thanks again!
  6. hj
    connector
    DeSanko, Marvel connector, waste and vent connector, trap adapter, and maybe others, all of them refer to the same thing. I am not sure that De Sanko invented it because we used them for decades before I heard his name associated with it. Which one you use depends on which part of the U.S.A. you are in.
  7. Gary Swart
    Sep 1, 2004
    Yakima WA
    Well, another day and I've learned more stuff! :)
  8. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    tomato tamato
Similar Threads: Wall Tube
Plumbing Forum, Professional & DIY Advice Cooktop exhausts through thinwall tube though foundation. rainwater problem Mar 2, 2017
Plumbing Forum, Professional & DIY Advice Weird thing with flushomatic toilet; tube connecting pipe to wall Aug 30, 2016
Plumbing Forum, Professional & DIY Advice 1 1/4 wall tube with threaded end Oct 20, 2015
Plumbing Forum, Professional & DIY Advice Old wall tube stuck Jun 9, 2013
Plumbing Forum, Professional & DIY Advice wall tube broken flush to tee Jul 11, 2012
