PVC vs. Metal vs cable vs conductor
Discussion in 'Electrical Forum discussion & Blog' started by ironspider, Aug 25, 2011.
  1. ironspider
    ironspider Member
    Jul 26, 2008
    Michigan
    Greetings all, I'm back with another question for the pros on the deck area I'm working on.
    Okay so I plan to add three receptacles to the side of the house (which is brick) to provide some receptacles to the covered portion of the deck. So I have some questions here and a diagram of my intended battle plan.
    1. Is my plan below legit? Can I tap into the back of an existing box inside the house to bring my power outside? If so, can I bring it right into an outdoor box or do I have to bring it into an LB first and then go from the LB to a receptacle box 4 or 5 inches down from it?
    2. Conduit. Should I use PVC for this or rigid metal? Does PVC look considerably crappier than metal? Are both "paint-able" since i think the lady of the house is not going to want bright silver or dull grey right there.
    3. Wire/cable. Should i use THHN/THWN or UF? If I go PVC can UF be run inside PVC conduit?
    4. Conduit Fill. What size PVC or metal conduit would I need to use for a single 12/2 UF wire or 3 #12 THHN/THWN wires?
    Thanks in advance!
  2. jadnashua
    ANy of the receptacles outside must be GFCI protected. Now, you could put one at the beginning of that chain and protect those further down the chain by using the load terminals to feed them. So, from a technical standpoint, it can be done. Now, whether it is wise or to code, I'm not sure.
  4. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Not out the back but out one of the holes provided for a cable would be fine.
    Use either raceway you desire and from the first box to the others make sure the conductors has a “W” such as THHN/THWN conductors. UF could be pulled in either but it is harder to installed and not needed.
    If you choose EMT make sure to use the correct fittings and bond the metal boxes. PVC will not hold paint as good as one of the metal raceways.
    As has been pointed out protect all devices with GFCI.
  5. Jim Port
    Jim Port Electrical Contractor
    Aug 22, 2009
    Maryland
    Don't forget the weatherproof-in-use covers.
  6. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    Just to reiterate, I'm pretty sure 1/2" is plenty for 3 12 gauge conductors...?
Similar Threads: Metal cable
Electrical Forum discussion & Blog Proper grounding of 3-wire submersible pump in metal well casing Jan 23, 2017
Electrical Forum discussion & Blog Using Madison Clips with new work metal box Mar 14, 2015
Electrical Forum discussion & Blog Using grounding bar inside 3-gang metal outlet box Mar 14, 2014
Electrical Forum discussion & Blog Can three #8 and one #10 wires be in ½†metal conduit? Aug 1, 2013
Electrical Forum discussion & Blog Make metal glow with electricity Feb 26, 2013
