PVC transition to Cast Iron
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by GoVolz, May 31, 2014.
  1. GoVolz
    GoVolz New Member
    May 31, 2014
    Chattanooga, TN
    I'm remodeling my bathroom and extending the shower 6 feet further left if the picture and the toilet 3 feet left of it's current location. My idea is to cut just left of the cast iron vent in and between the toilets transition piece and connect with a similar size pvc pipe. And basically extend it in the same direction as the way the current cast iron is by extending it 5 feet or so. Leave a clean out at the end just as the cast iron has and tie in the new shower location and toilet location. Is this logical or is there a better way. Also I'm assuming I will have to tie in a new vent since the shower and toilet are further from the stack. Is thag correct? Your help is appreciated. Thanks.
  2. Terry
    Aug 17, 2004
    The shower vents within five feet, and the toilet within six feet.
    [​IMG]
    A shielded coupling like these to prevent the pipe from shifting.
    I would measure the OD of the cast. If it's Something like 4-1/8" or 3-1/8" you will need a copper size on one end.
    Most new cast and plastic is the pipe size plus 3/8"
    The shower drain should be 2"
  4. GoVolz
    GoVolz New Member
    May 31, 2014
    Chattanooga, TN
    Well the toilet should be fine as far as venting, when I move the toilet from it's current location in the picture it will be less then 6 feet from the stack. But the shower will be further then the toilet. Roughly 7-8 feet from the stack. So wouldn't I still need to tie a new vent for the shower into the stack.
  5. GoVolz
    GoVolz New Member
    May 31, 2014
    Chattanooga, TN
    The two pictures are the current plumbing set up. The new toilet and shower will be extended further left.
  6. GoVolz
    GoVolz New Member
    May 31, 2014
    Chattanooga, TN
    I appreciate your help terry. I'll be sure to get the couplings you mentioned.
  7. Terry
    Aug 17, 2004
    Yes, you may need to bring that vent back and tie in.
  8. GoVolz
    GoVolz New Member
    May 31, 2014
    Chattanooga, TN
    Ok thank you for our help. That helps me understand better.
Similar Threads: transition Cast
Plumbing Forum, Professional & DIY Advice Advice for transitioning PVC to non-standard cast iron Oct 10, 2015
Plumbing Forum, Professional & DIY Advice Copper to PEX-A Transition Underground Monday at 1:45 PM
Plumbing Forum, Professional & DIY Advice What kind of drain pipe is this? How can I best transition to PVC? Feb 8, 2015
Plumbing Forum, Professional & DIY Advice Abs-PVC Transition Cement for just Abs by mistake May 6, 2014
Plumbing Forum, Professional & DIY Advice transitioning from galvanized to copper Dec 16, 2013
