PVC to brass
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DIY, Jun 26, 2008.
  1. DIY
    DIY Member
    Dec 24, 2006
    Florida
    Without starting a great debate as i've seen on here before ,and just recently regarding a similar subject. Threading a PVC female coupling onto a male brass fitting? Teflon tape,pipe dope,both, or nothing?
    Thanks all
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    I use about three wraps of teflon tape to do that.
  4. jadnashua
    Reliability is much better if you can configure it to use a male pvc fitting into a female brass one. WHen you tighten the two together, the brass can handle the squeeze, the plastic in the female fitting just expands and could eventually split. SO, don't overdo it and change if you can to put a male into brass.
  5. jimbo
    jimbo Plumber
    There is great danger of overtightening plastic to metal, and female plastic fittings are prone to crack if overtightened.
    My theory is that too tape makes the male too fat, and can cause problems. SO, two wraps of thin white tape, or one wrap of yellow tape. Brush on a thin coat of Great White dope.
    The PPFA recommends this procedure : Hand tight, then 1/2 turn by wrench. If necessary to stop a drip, additional 1/2 turn.
    Because plastic is soft, and the tape and/or dope is a lubricant, it is VERY easy to overtighten plastic to metal, distorting the plastic threads and causing a leak.
    If you are a person who has hands like Mighty Joe Young, then just hand tight often is enough. For most of us, the 1/2 wrench turn will finish the job.
    And as I have said before, if you are old enough to actually remember Mighty Joe Young, sit down and turn this job over to a youngster!!!
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Avoid screwing metal male threads into a plastic female whenever possible.
    You are talking about the 1998 "B" movie starring Charlize Theron right? LOL
    http://images.google.com/imgres?imgurl=http://l.yimg.com/img.movies.yahoo.com/ymv/us/img/hv/photo/movie_pix/universal_pictures/k_pax/_group_photos/charlize_theron22.jpg&imgrefurl=http://movies.yahoo.com/movie/contributor/1800019484/photo/224628&h=400&w=280&sz=43&hl=en&start=14&tbnid=WbGDjgdMSb6VzM:&tbnh=124&tbnw=87&prev=/images%3Fq%3Dmighty%2Bjoe%2Byoung%26gbv%3D2%26hl%3Den%26safe%3Doff%26sa%3DG
    [​IMG]
Similar Threads: brass
Plumbing Forum, Professional & DIY Advice Brass cleanout plug in older home Jan 31, 2017
Plumbing Forum, Professional & DIY Advice 3/4" threaded = brass or copper Jan 27, 2017
Plumbing Forum, Professional & DIY Advice Brass or stainless constant pressure manifold? Dec 28, 2016
Plumbing Forum, Professional & DIY Advice Newport Brass Bridge Faucet Oct 22, 2016
Plumbing Forum, Professional & DIY Advice Brass P-trap and Galvanized Steel Stub-Out Oct 13, 2016
