PVC to ABS tub drain
Discussion in 'Shower & Bathtub Forum & Blog' started by robb, Feb 22, 2009.
  1. robb
    robb New Member
    Feb 22, 2009
    Spokane, WA
    I am finishing my basement. There is a pea gravel cut-out in the concrete slab with a 2" cell core sch40 ABS stub. I have 3 questions:
    #1 - I was going to use a sch40 PVC tub drain/overflow set; can I connect to the ABS?
    #2 - When I remove the cap on the 2" in the pea gravel cut-out, will there be waste water?
    #3 - Do I refill the cut-out with the pea gravel once I'm connected and the tub is in? (I will have access thru an unfinished room)
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You will need to make the connection with a banded coupler. ABS and PVC being different chemically, can not be solvent welded together. I say this in spite of the fact that there is supposedly some kind of wonder product that will work on both. There should be no water, the trap is still below your connection point. Refilling with pea gravel probably is really necessary, but I might do it anyway. Often this space has a thin layer of concrete.
Similar Threads: drain
Shower & Bathtub Forum & Blog Shower drain size going from tub to shower Saturday at 4:17 PM
Shower & Bathtub Forum & Blog Roman Tub/Drain...Want to Remove Feb 20, 2017
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Feb 14, 2017
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
