pvc to abs glue
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by thenewguh, May 27, 2006.
  1. thenewguh
    thenewguh New Member
    May 27, 2006
    Hello all.
    I searched around first regarding connecting pvc to abs and found that some folks are ok with using transition glue, but didn't see anything about using a hubless encased in concrete. So, here goes.
    My problem: I have abs drain pipe in a shower i'm remodeling. I'm on a slab in california. I have access to the complete trap, which I plan on cutting out and replacing. Problem: My drain is pvc and I don't want to wait another week to reorder an abs drain if possible.
    So, can I:
    1) put a new abs trap on and use transition glue to glue the pvc drain to the abs riser?
    or
    2) put a new abs trap on and use a fernco hubless to connect the pvc drain to the abs riser?
    I will be filling up the hole with concrete, so should I be nervous about using the fernco connection since i'll be encasing with concrete, or just go with the transition glue and call it macaroni?
    thanks!
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    I have used solvent cement that is labeled for ABS and for PVC. It seems to work well. It was available at HD. I always use purple primer but many people don't like the looks of the runs on white PVC, so you can probably use clear primer.
  4. thenewguh
    May 27, 2006
    thanks for the reply, bob.
    And, did you only prime the pvc and not the abs with that solvent?
  5. Bob NH
    Oct 20, 2005
    New Hampshire
    I have a technique for assembling plastic pipe joints.
    First, cut the pipe square, using whatever tooling is required based on your skill.
    Then I de-burr and chamfer the outer edge, and the inside edge of the pipe if the flow is into the pipe.
    I thoroughly clean and prime every surface, until the printing on the pipe is removed. Then I put adhesive on every surface; no "holidays" or missed spots.
    I assemble the joint in a way that lets me give it a quarter turn as I finish the assembly, all the way to the stop in the fitting, and hold it in place for a few seconds so it doesn't push out due to the tapered fitting bore.
    I never get a leak at a cemented joint.
  6. Terry
    Aug 17, 2004
    [​IMG]
    You could use a shielded coupling like this, and skip the glue all together.
Similar Threads: glue
Plumbing Forum, Professional & DIY Advice Tricks to increase work time with ABS glue? Mar 5, 2016
Plumbing Forum, Professional & DIY Advice Anyone heard of a PVC joint holding for 11 months with no glue? Feb 5, 2016
Plumbing Forum, Professional & DIY Advice Forgot to glue the PVC fitting after primer - Can I take off & re-use it? Oct 1, 2015
Plumbing Forum, Professional & DIY Advice kitchen sink pluged/glued/broken cleanout Apr 20, 2015
Plumbing Forum, Professional & DIY Advice Would a tailpiece be glued into waste line? Dec 11, 2014
