Jesse Kershaw
Looking for some help on PVCsolvent cement. There's the normal Oatey at home stores but there's a bunch more options online. Heavy duty, heavy body, medium body, "hot", etc.
Those cement's that work for larger diameter pipe I assume would be stronger on small diameter pipe.
Can someone explain the difference between all these?
Is Hercules and Oatey the same?
And are some primers better than others?
I'm asking all this because I just finished plumbing my house and i used three cans of cement Oatey cement and purple primer. The second and third cans seemed funny. Thicker than what I've used it in the past and drying quick but then not completely, gummy for a long time. Pushing the joints apart like I've never seen, I had to hold them together a long time with force. And I did buy it new so I thought maybe it was the heat and humidity causing this funny condition. Long story short when I checked the system with water it was like it was raining in the house. Leaks everywhere. So now I want the best I can use even if it's overkill to avoid a third time.
Thanks for your help
