PVC Shower Drain help!
Discussion in 'Shower & Bathtub Forum & Blog' started by squbbles, May 26, 2014.
  1. squbbles
    squbbles New Member
    Jan 22, 2014
    Okanagan, BC
    Replaced my old shower with new acrylic base and surround. New base is slightly higher, thus drain pipe does not come up quite as high.
    My question is, can I trim the thick rubber gasket that slips onto the drain pipe before installing the plastic compression ring? I tried installing it as is, but the top half of the rubber seal simply folds over the top of the pipe once ring is installed leaving a smaller opening to the drain pipe.
    Any ideas?
    Thanks in advance for all your expertise.
  2. dhagin
    dhagin builder:anti-builder
    Jan 22, 2014
    builder
    oahu
    Cut the 2" riser down with an inside pipe cutter, available at the local hardware of box store, install a coupling, then install a new riser that is the correct height. :)
  4. squbbles
    squbbles New Member
    Jan 22, 2014
    Okanagan, BC
    Thanks dhagin. I appreciate the advice.
    Is this the only option? I'm not sure that a coupling will fit through the drain body.
    Also, I read that some people use silicone caulk to help the rubber gasket slip down the pipe and help with creating a good seal. Is this necessary?
    Cheers.
  5. Terry
    Aug 17, 2004
    If you have already installed the pan and no longer have access to the p-trap, then you may not have much choice. It's too late to do the proper thing anymore.
    They also make a lead packing that may work. I don't look at Silicone for that as being a proper installation. I guess you can try it, but I've never resorted to that.
Similar Threads: Shower Drain
Shower & Bathtub Forum & Blog Cast Iron Shower drain on concrete Mar 22, 2017
Shower & Bathtub Forum & Blog Odd Shower Drain Rough In Mar 5, 2017
Shower & Bathtub Forum & Blog Shower drain size going from tub to shower Feb 25, 2017
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
