PVC repair irrigation water supply line from the street
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by themp, Apr 27, 2011.
  1. themp
    themp Member
    Feb 5, 2008
    Raleigh, North Carolina
    I have a straight 1 inch PVC line from the water meter that got cracked in the middle of the yard. Since I have no flex in the line, unless I dig up a large portion of the line, what is the best way to repair this? I looked at a 1 inch PVC union and it would seem I have to be very exact on getting the two union faces tight because I have no flex that can allow the two sides to move in tighting up the union. My other thought is to just use a flexible 1 inch line and clamps. Or I have to make four 90 degree turns to allow the pipe to flex at the union. Like a large U in the line with the union at the bottom of the U. And this supply line is at 90psi from the city.
    Any other tricks?
    Thanks, Tom
  2. Terry
    Aug 17, 2004
    Or.................use the four 90's without the union.
    Point the first set of 90's the same direction, and then drop the length of pipe with the street 90's into the waiting 90's.
    If you have room in the ditch, you could also use two 90's for the connection.
  4. themp
    themp Member
    Feb 5, 2008
    That is a good trick!
    I never was three dimensional...
  5. Stormrider49
    Stormrider49 Slave to rentals
    Jan 7, 2010
    Property Manager
    Nevada
    Since it is PVC, why not use a slip-fix repair coupling?
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Yep! Slip repair couplings work great on irrigation lines.
Similar Threads: repair irrigation
Plumbing Forum, Professional & DIY Advice Lead Bend Repair? Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Faucet Handle Removal & Leak Repair Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Kohler Forte Tall Single Lav Repair, K-10217 Jan 14, 2017
Plumbing Forum, Professional & DIY Advice Tub Drain Leak - Where to repair Jan 9, 2017
Plumbing Forum, Professional & DIY Advice Main Shut Off Stripped & Repaired..? Dec 26, 2016
