PVC pipe (soil stack) to horizontal main line
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by vvladovskiy, Feb 22, 2011.
  1. vvladovskiy
    vvladovskiy New Member
    Feb 22, 2011
    98040
    I want to change my old cost iron soil stack and horizontal pipe to PVC. The horizontal pipe has a slope away apox 4 degrees
    How I can connect the 4 in PVC pipe (soil stack) to the horizontal PVC pipe with the 4 degree angle?
    What fittings will fit? Street elbow 45 plus 45?
    Thank you.
  2. Terry
    Aug 17, 2004
    A 45 is 45 degrees, and you need to move it only 4 degrees?
    Doing nothing is closer then adding something. Fittings from vertical to horizontal are set up for 2%
  4. vvladovskiy
    Feb 22, 2011
    98040
    Thank you for prompt response, well I need slop away for 4 degrees. What fittings should I use in this case?
    The Long Sweep Elbow 90 Deg, and then push the pipe down on the far end?
  5. vvladovskiy
    Feb 22, 2011
    98040
    Another words...
    What is the proper way to angle horizontal PVC waste pipes for 4 degrees (or 3, 5, 6 degrees)?
    If you connect the vertical and a horizontal pipes, they seem to want to stay straight. If you try to angle it, it pulls out of the 1/4 turn a bit.
    I assume this is the way it is supposed to be and is why the collars are deep and the solvent helps make the seal.
    How do you know that the pipe is on too much of an angle?
    The reason I ask is because I have to juggle some angles when trying to tie new pipes into old.
  6. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Each joint has enough "slop" in it that when solvent welded together you can get a little bit of pitch out of it. If you need a couple more degrees, placing a common hub x hub coupling a few inches from the bend should get you there.
Similar Threads: pipe (soil
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Tuesday at 1:12 PM
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Monday at 8:27 AM
Plumbing Forum, Professional & DIY Advice Dumb, probably repeat laundry standpipe question Feb 16, 2017
Plumbing Forum, Professional & DIY Advice Plumbing leak on plastic pipe Feb 15, 2017
Plumbing Forum, Professional & DIY Advice PEX Pipe in attics? Feb 14, 2017
