PVC coupling question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by gtfrueh, Jun 26, 2013.
  1. gtfrueh
    gtfrueh New Member
    Jun 26, 2013
    PA
    Hello,
    I need to couple two pieces of 1-1/2" PVC pipes together, but I need it to also be strong. I bought the standard fitting at Home Depot, but the total length of the fitting is 2-1/2 inches. I can only slide the PVC pipe into the fitting about 1-1/4 inches. I don't think this will provide the strength I need.
    Is there a 1-1/2" fitting that is longer than 2-1/2 inches? Even a few inches on either side would be good.
    Thanks,
    George
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The standard fitting will be plenty strong. You must understand that PVC is not technically "glued". The so-called glue or cement is actually a solvent that liquifies the surfaces of the pipe and fitting for a few seconds. The allows the pipe of fully engage the fitting. The liquified surfaces blend together and form a chemical weld. The resulting joint is permanent and as strong or stronger than the rest of the pipe.
  4. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    If your use is just for the strength you could use a coupling that's used for water lines. It's longer than a DWV coupling and the slips are also deeper.
    John
Similar Threads: coupling question
Plumbing Forum, Professional & DIY Advice CPVC Coupling Question Jul 10, 2014
Plumbing Forum, Professional & DIY Advice coupling questions Feb 13, 2014
Plumbing Forum, Professional & DIY Advice Hubless coupling questions. May 24, 2010
Plumbing Forum, Professional & DIY Advice newbie question on drain couplings & solids hanging up? Sep 15, 2009
Plumbing Forum, Professional & DIY Advice leaking coupling question Jun 17, 2008
