PVC - Copper Pipe Joint
Discussion in 'Irrigation / Sprinkler Forum' started by jgalway, Jul 14, 2008.
  1. jgalway
    jgalway New Member
    Jul 14, 2008
    The PVC pipe broke at the joint between the 1" supply line and the primary valve right at the end of the threaded copper pipe. Do I replace the threaded copper end or how do you remove the threaded pvc from the copper?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Is the threaded copper a female adapter? If so, it might quicker and easier just to cut the adapter off, sweat a new one on and not even attempt to remove the broken PVC. To remove it, you'd have to make a couple of cuts in the PVC then pry the pieces out. You'd mess the copper threads up to a certain extent doing this which could make it difficult to get a leak free connection, and you'd not make very good wages saving the cost of a new adapter.
  4. jgalway
    jgalway New Member
    Jul 14, 2008
    New Adapter
    The copper fitting is female. So just grab a torch, take it off and add a new one? Any special considerations for solder, gas ??
  5. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    95/5 tin/antimony solder, Oatey No. 95 tinning flux, and a propane torch will work fine.
    Very good cleaning is important.
  6. hj
    joint
    Leave the copper alone, and remove the plastic piece from the female adapter. There are several pipe removers that will work.
  7. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    You can always melt the remaining PVC and pry it out of the fitting.
  8. jgalway
    jgalway New Member
    Jul 14, 2008
    Used the torch to remove the female fitting. It came off easily and so did the PVC which was quite soft. Reattached the fitting. Will be testing the system today. Thanks
  9. hj
    pvc
    How did you reconnect the pvc to the copper? Not with another male PVC adapter, I hope.
  10. Mr_Pike
    Mr_Pike New Member
    Jun 28, 2007
    Nebraska
    I quit using PVC male adapters a long time ago. If you need to make a connection to female Iron or copper pipe. Cut a Pipe Nipple in half and use a coupling to join half to the PVC. You will have a joint that is twice a strong...
    A PVC male adapter might as well be perforated at the bottom the the threads.
Similar Threads: Copper Pipe
Irrigation / Sprinkler Forum drip irrigation with 1/2" copper pipe Mar 28, 2009
Irrigation / Sprinkler Forum plan to cut the copper pipe Jul 24, 2008
Irrigation / Sprinkler Forum Burst Pipes, can I make a transition from copper? May 12, 2008
Irrigation / Sprinkler Forum Need help to fix broken copper tubing Nov 7, 2015
Irrigation / Sprinkler Forum Pvc vs copper under patio slab Dec 7, 2010
