PVC Cement smell after 4 weeks
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rbahamas, Apr 19, 2009.
  1. rbahamas
    rbahamas New Member
    Apr 18, 2009
    a plumber changed an outside valve as well as the inside valve some 4 weeks ago, I just connected the sink inside and when I turned the water on there was a strong smell of PVC cement/glue. Is this normal?
    Thanks
    Rory
  2. Waterwelldude
    Waterwelldude Well driller,pump repair. and septic installer
    Feb 11, 2009
    Texas
    Yes, since you just started using the sink, there may be a little smell. It may have been trapped in the line. Now that you have it hooked up, and using it. It should go away pretty quick.
    Travis
  4. rbahamas
    rbahamas New Member
    Apr 18, 2009
    ok thanks, cause i let it run through a while and it was still a strong smell. The valves werent even for my apartment but I guess that is all joined together so its the same water. My concern was that if the plumber knew what he was doing and used the right cement/glue. ill check it again a little later and see how it is. Thanks.
  5. Waterwelldude
    Feb 11, 2009
    Texas
    As far as I know, all cement/glue smells the same.
    I am still waiting for the one with the fresh winter green aroma to come out..lol..:D
    Travis
  6. iminaquagmire
    iminaquagmire DIY Senior Member
    Dec 16, 2007
    FF/EMT
    Why would there be PVC on the water supply side anyway? It is not code approved for hot water and any valves that I know of would not be suitable for potable water usage either. Are you sure you don't mean CPVC? I'm sure over time it will dissipate either way, but I'm not sure how running water in your sink would release any smell.
  7. rbahamas
    rbahamas New Member
    Apr 18, 2009
    down here we have no code for that, and we dont drink the water, so its all PVC (far as i can tell). I dont even know what CPVC is :D
    Yep i ran the water again tonight and there came the cement smell. Its actually in the water itself as it comes off on rag when i wet it.
Similar Threads: Cement smell
Plumbing Forum, Professional & DIY Advice smelly toilet bowl even after replacement! Jun 26, 2013
Plumbing Forum, Professional & DIY Advice Cast iron tub ledger board placement Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Moen Chateau knob replacement ? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice P Trap replacement Feb 5, 2017
Plumbing Forum, Professional & DIY Advice Tub-Shower Valve Stem ID/Removal/Replacement Jan 31, 2017
