PVC Cement on pipe with flowing water
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mwolf00, Mar 26, 2012.
  1. mwolf00
    mwolf00 New Member
    Mar 26, 2012
    Virginia
    My old pressure tank for my well gave out yesterday so I was forced to replace it today. Our well is about 400 feet from our home on the other side of a hill. The incoming pipe is 1" PVC which I had to cut in order to perform the replacement. I had removed the circuit/safety switch prior to any work so the well pump had no power (I had also removed the wiring from the pressure switch). I was not surprised to see water come out after cutting the PVC pipe but I was surprised that it did not even slow after 20 minutes (I'd guess 1 gallon per minute). I decided that it might not stop so I used my PVC cement to put it back together while the water was flowing (I did open the drain on the new tank so no pressure would build up as I worked). FWIW - I was using the 2-part standard PVC cement (purple primer plus glue). The new connection is dripping a drop or two every 10 seconds. I know that I need to remove that weld and try again but I'm trying to figure out my best plan of attack to succeed the second time around. Also, how pressing is this? Do I need to repair it immediately or can it wait a day or two (I don't want total failure!!!). Thanks for any input!
  2. Terry
    Aug 17, 2004
    If you can't stop the flow, you might look at dressler couplings.
  4. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    BC
    Use this, allow 30mins before pressurizing the line.
  5. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    thrice the price of the regular stuff and works just about the same LOL
  6. mliu
    mliu Member
    Feb 7, 2007
    California
    Are you sure there are no shut-offs that you can use to stop the flow of water? If not, this would be a good time to add some ball valves to your system.
    I would never trust any pressurized PVC joint that was not completely dry when the joint was solvent welded, no matter what "glue" was used.
  7. michielsemma
    michielsemma New Member
    Mar 26, 2012
    Utah
    If the pipe is new, it only takes about 5 minutes to get a bond strong enough to hold water pressure. I would however let it dry for 3-4 hours minimum and over night nominally, just to allow the solvent to cure. If you haven't bought the pvc glue yet, buy the "heavy duty clear" made by a company called Oatey. This is the strongest stuff you can buy in the box stores.
  8. Jerome2877
    Aug 25, 2009
    BC
    http://www.reefcentral.com/forums/showthread.php?t=2035935
    Good job on the copy/paste LOL.
    That glue is no different than the stuff the OP tried already! I have used the wet dry glue many times in wet conditions and it has always worked. It is extremely fast setting and made for these situations. Do you own stock in Oatey or are you just trying to sound like you know something about plumbing?
  9. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    http://www.reefcentral.com/forums/showthread.php?t=2035935 This time, it's copy and paste of 2 posts with a minor edit.
    Nothing original to contribute? Come on, you must have something to say of your own:)
  10. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    That telescoping coupler is not a Dressler coupler. I did a hurried search for a good photo of a Dressler and finally found that **** has some listings for them. Not suggesting you buy one there, but you can see what they look like. I have used the telescoping coupler successfully on 3/4" sprinkler lines, but I'm a bit doubtful that they would be the best for your situation.
  11. mwolf00
    mwolf00 New Member
    Mar 26, 2012
    Virginia
    Ok - so the dressler coupling is a BUST - literally. I do not recommend them for this type of repair. I put one on and was fortunate to be only about 20' away when it BLEW. I thought that I might not have tightened it enough or had the rubber gaskets slid far enough up the pipe, so I gave it a second try. Sure enough, it blew again. So, now I am going to plan C. I've cut the pipe on the vertical and installed a ball-valve. I am waiting 2 hours for the joint to dry and then stopping the flow (completely if all goes well). 2012-03-29 11.01.53 small.jpg
  12. mwolf00
    mwolf00 New Member
    Mar 26, 2012
    Virginia
    I've done a little thinking about the absense of a cut-off before the pressure tank. I'm not sure if having one (like I just installed) meets code. If you think about it, giving the home-owner the ability to stop the flow of water before the pressure switch can be a very bad idea. At best, you could burn out your well pump. At worst, bust the pipe somewhere. I would also guess that the builder's plumber didn't even have to consider this problem since the pipes were all installed before the well pump was run for the first time. They wouldn't have had to deal with the syphon effect that I am encountering.
  13. mliu
    mliu Member
    Feb 7, 2007
    California
    What solvent cement did you use on that joint? I've never seen any that's baby-poop brown.
  14. mwolf00
    mwolf00 New Member
    Mar 26, 2012
    Virginia
    It is Oatey Flowguard Gold. Although it can be used without primer, I still used the primer which might account for the color being a bit unusual.
  15. nukeman
    nukeman Nuclear Engineer
    Nov 20, 2009
    Nuclear Engineer
    VA
    That is for CPVC. It looks like you are using PVC, correct?
  16. mwolf00
    mwolf00 New Member
    Mar 26, 2012
    Virginia
    Yes. I am using PVC. And now that you mention it, I re-read the can and it does say "CPVC Cement". :confused:
    Does that mean I have to cut all of this out and try again??? I used it because it was thicker and I felt it would stay on better when it had the water splashing over it.
  17. mwolf00
    mwolf00 New Member
    Mar 26, 2012
    Virginia
    Okay - so I found this FAQ Page that seems to suggest that I'm okay. I am a rank amatuer so I will defer to those on this board with more experience. Hopefully, I'm in the clear...
  18. Hackney plumbing
    Hackney plumbing Homeowner
    Jan 6, 2010
    Alabama
    When using a dressler coupling the pipe must be restrained and not allow movement of the pipe....on each side of the coupling. That and over-tightening are two common mistakes.
  19. mwolf00
    mwolf00 New Member
    Mar 26, 2012
    Virginia
    That makes sense. The pipes pushed themselves apart when under pressure. Fortunately, the coupling failed quickly so I was able to minimize the colateral damage.
    The coupling might have worked if I'd put a pressure treated 2x6 under the whole assembly and clamped it all down... Hopefully, I don't need a plan D. ;)
  20. mliu
    mliu Member
    Feb 7, 2007
    California
    You've said the water is just siphoning (when the well pump is off). Is that correct? How much pressure is generated by the water? Can you put your hand on the end of the pipe and easily stop all the flow?
  21. mwolf00
    mwolf00 New Member
    Mar 26, 2012
    Virginia
    The flow is pretty steady - I'd guess @ 1 gallon per min. It squirted into my face when I tried to put a rag over it but I would guess that I could block it with my hand without too much effort. And yes, that is with the well pump completely off (circuit breaker removed). I had it flowing into the rig in the picture (redirecting it directly into the sump) for 2 hours with no drop in flow rate. On the plus side, I guess I'll always have a little water even when the power is out :eek:
    At this time, it is all back together with no leaks, but it has been noted that I might have used the wrong cement (CPVC cement on PVC pipe).
Similar Threads: Cement pipe
Plumbing Forum, Professional & DIY Advice leaking waste pipe in cement floor Sep 7, 2015
Plumbing Forum, Professional & DIY Advice Waste Pipe Replacement - Need Advice Jan 10, 2014
Plumbing Forum, Professional & DIY Advice Opinions/Help/BS Detector Needed - Clay Pipe Replacement vs. Maintenance Jul 12, 2013
Plumbing Forum, Professional & DIY Advice Replacing 1m length of sewer pipe with suspected cement blockage Jun 30, 2013
Plumbing Forum, Professional & DIY Advice What kind of price should I expect for this job? (replacement of galvanized pipe) Oct 21, 2012
