Putty for AC lines
Discussion in 'Remodel Forum & Blog' started by SteveW, Oct 1, 2006.
  1. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    Just wondering - what do the HVAC folks use to caulk around the refrigerant lines where they enter the house? The stuff they use here in the midwest feels a lot like plumber's putty - never hardens, and you can kind of smoosh it around if part of the hole in the siding is exposed.
    In my situation, it has pulled away too much to put back into place, and I'd like to add some more. I haven't seen any non-hardening caulk or putty at the store, other than plumber's putty -- should I use that?
    Thanks.
    Steve
    Omaha, NE
  2. George R
    George R New Member
    Mar 7, 2005
    Central Illinois
    No, don't use plumbers putty. I don't know what you call what you are describing, but it is available in most big box stores. It comes as a 1"x2"x6" grey colored "brick" wrapped in heavy clear poly. I think you may find it in the electrical dept. as it's used to seal electrical conduit penetrations as well.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    In the trade it is known as thumb gum.
  5. SteveW
    Feb 11, 2005
    Omaha, NE
    Thanks, gentlemen - I'll look around the electrical dept. -
Similar Threads: Putty lines
Remodel Forum & Blog Break Old Plumbers Putty Bond? Aug 20, 2005
Remodel Forum & Blog Dishwasher and Icemaker Supply Lines Question Dec 14, 2016
Remodel Forum & Blog Concrete slab woes; need new water lines, radiant heat is leaking. Apr 24, 2016
Remodel Forum & Blog Floor Tile and Chalk Lines Aug 3, 2010
Remodel Forum & Blog Replace copper lines with PEX? Jun 10, 2010
