Putting elbow in soil stack in Canada
Discussion in 'Canadian Plumbing Code Questions' started by causie, Jun 21, 2010.
  1. causie
    causie New Member
    Jun 21, 2010
    Ottawa
    I've just torn out gyproc above sink in order to put a sunken medicine cabinet in wall. Unfortunately the soil stack runs right up the middle. Is it OK to put elbow in to make stack run around medicine cabinet?
  2. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    It's probably not a "stack". That term is thrown around quite losely. It's probably simply just a vent. If it's just a vent then you can most certainly offset it around the cabinet. And if it's a wet vent extending through more then one story it's called a "soil-or-waste stack wet vent" and there are some rules that come into play when putting offsets in them. But none of these rules would probably apply to you anyway because you're offsetting mabye 2 feet. And you're allowed to offset a vertical wet vent by up to 1.2m for pipe sizes 2 inches and less.
  4. causie
    causie New Member
    Jun 21, 2010
    Ottawa
    Thanks so much for your input. Do you think it's an issue to do it at 90 degrees? This would mean 4 elbows.
  5. hj
    As long as it is just an air vent, you can use as many elbows as necessary, and offset as far as you have to.
  6. DavidTu
    DavidTu Member
    Dec 3, 2009
    Seattle, WA
    Even for the vent, though, if you set it going horiztonal for the offset, it has to be 6" above the lip of the sink before you do so (assuming it is the sink's vent).
  7. Terry
    Aug 17, 2004
    This is in Seattle, UPC plumbing code.
    They don't have "soil-or-waste stack wet vents" here.
    If it is indeed a vent, then you can use 45's below 42" or "waste" fittings, not vent 90's
    I don't even buy vent 90's. They cost more and can only be used on vents, whereas medium 90's can be used many more places.
  8. locus123
    locus123 New Member
    Sep 2, 2009
    Ontario
    What if it were the actual stack itself? In my kitchen, the stack (which has a tub, sink and toilet feeding into it in the bathroom above), runs on the outside of the 2x6 wall. I was thinking of adding an offset of about the size of the stack (so 3", with 2x45's at the top and 2x45's at the bottom), just to recess it behind the wall. This would avoid having one of those unsightly "boxes" in the middle of the countertop. I would only offset it for the distance between the upper and lower cabinets - I don't mind losing the space in the cabinets.
  9. Doherty Plumbing
    Jun 22, 2009
    Penticton, BC
    I think you'll find the answer to this question in my post above.
Similar Threads: Putting elbow
Canadian Plumbing Code Questions short radius 90 degree elbow under toilet Mar 12, 2013
