Putting a T connection at the natural gas line
Discussion in 'HVAC Heating & Cooling' started by bis, May 10, 2010.
  1. bis
    bis New Member
    May 10, 2010
    california
    Hello,
    I have natural gas pool heater connection at the inlet close to gas meter.It is in T shape.
    At the T,One connection to house supply and the other to pool heater.
    City inspection guy failed inspection saying install full size T at house side of gas meter line.I am sure natural gas is supplied at some pressure wether you put T connection at the source or take one side T off and put T connection on pipe entering the house should't make any difference.You could easily slide that T joint to source inlet and you have the same situation what we started with.This is the law of mass transfer.Total gas comming into residence
    =Gas supply to pool heater+gas supply to house.
    How can it reduce the gas supply to house completely when pool heater is operating?
    I am sure pressure can't drop to nill on house side of pipe.
    Can you please Give me some input to this problem.Will it really reduce gas supply to house?
    Naem
  2. nukeman
    nukeman Nuclear Engineer
    Nov 20, 2009
    Nuclear Engineer
    VA
    Can you add a pciture? I am not sure if I understand the situation.
  4. jadnashua
    Hard to tell without seeing what you have. What are the BTU requirements of stuff on each branch? And, what size pipe and T is it? What size pipes feed each side? The pressure will only be constant when no flow. The regulator will try to keep the pressure up, but it also depends a lot on the length of the pipe, it's diameter, how many turns it takes, and the BTU (flow) requirements. If there are reductions anywhere, it can mess up the flow.
  5. hj
    Have absolutely no idea what you are talking about. We would have to see where AND how that tee was installed. Gas behaves slightly differently than water, but the codes equate the two. What WILL work and what is REQUIRED, are not always the same. Show us a picture of what your connection looks like.
Similar Threads: Putting connection
HVAC Heating & Cooling Putting back on the pieces to my Payne furnace. Nov 15, 2015
HVAC Heating & Cooling correct plumbing for radiant connection to heat loop Jan 13, 2012
HVAC Heating & Cooling Need help with Carrier Furnace and LP connection Sep 15, 2011
HVAC Heating & Cooling erratic smoke alarms and heat pump connection? Feb 21, 2010
HVAC Heating & Cooling 24v thermostat connection question Jan 8, 2009
