Pushing lake water 500' through 1" sch 40- Uggh
Discussion in 'Irrigation / Sprinkler Forum' started by Daltex, Jul 1, 2013.
  1. Daltex
    Daltex New Member
    Jan 31, 2008
    Texas
    I bought a lake house with 2 acres to irrigate. The existing system uses a 3hp pump connected directly to a manifold with 8 zones feed off of it. The problem is that the pressure at the heads of most of the zones is closer to 20 psi. The runs vary in lenght up to 500'. All pvc is 1" sch 40.
    I know that even using 1-1/2" pipe would probably work for whatever reason they put in 1".
    Question: Considering that there is seperate runs for each zone, would it be feasible to tie multiple zones together along with decreasing nozzle size and get the pressure up to 30-35 psi?
    I tapped it at the manifold behind all the valves and the pump is putting out 43 lbs. there so would two 1" runs of up to 500' at a much lower velocity due to the lower orifice nozzels get the pressure up there?
    I plan on running a 2" line to the middle of the run and using that for the valves with 1-1/2" pipe at a later time but due to construction I won't be able to do this for another year or so.
    Thanks !!
  2. Daltex
    Daltex New Member
    Jan 31, 2008
    Texas
    After reading more about my situation on other forums I think I will leave it as is until I can upsize the main feed line to a 2" line.
    If I reduce the nozzle size but add an additional zone with it's seperate 1" line it seems the pressure would rise but not significantly. The main concern I have learned is that by reducing the nozzle size I would experence a significant amount of wind drift to the water stream from the rotors. The area is windy most of the time and I need to stay with larger nozzle sizing to reduce the effects of the wind.
    I'll just wait until the time I can increase the supply line and then redesign the rotors (number per zone and nozzle size) to fit the pump performance curve. A few of the zones have not only long runs but a significant elevation rise.
  4. Terry
    Aug 17, 2004
    It should have been 1-1/2" pipe for that distance.
    http://terrylove.com/watersize.htm
    My parents home had something similar for the irrigation, theirs was 3/4" and wouldn't do one zone.
    We ditched in new 1.5" and the problem was solved.
  5. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    The key is balance, when you have different lengths and different heads, then you will have different flow.
    Flow control is key.
    It sounds like You need to up the pressure. You may have to many Outputs running at once, If so bigger pipe won't help, if there is no pressure on the input.
    Have Fun.
  6. Daltex
    Daltex New Member
    Jan 31, 2008
    Texas
    I agree that an increase in pressure is the key. The problem is how to increase pressure when the friction loss of the 1" pipe is so large for the 500' run. I'm sure that if I dropped the flow to a few g/m that the pressure would increase but I think that the pump would be much more efficent if there was minimal friction loss. There is no elevation increase on the furthest zone and through the 1" pipe the flow drops alot. Increasing it to 1-1/2" or 2" would be a dramatic decrease in friction loss thus increasing the flow rate. The increase in flow rate will decrease the run time thus saving $$ on electric expense.
  7. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Very True, IF you have plenty of pressure at the pump outlet.
  8. Murphy625
    Murphy625 Member
    Jul 7, 2013
    Michigan
    You could just install a second pump in series with the first.... The first pump would push its discharge into the second pump which would discharge into the 1 inch line. The pressure would build in the first, then build even more in the second.. You'd probably double the PSI instantly.
    I never said it was energy efficient, but you're limited to overcoming friction losses.
  9. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Some key information is what are the distances between the source and the various zone valves. The upstream side of the zone valves is where you want to be generous with pipe sizing, especially if there are any long runs. This relates to water hammer in the zone valves.
  10. Daltex
    Daltex New Member
    Jan 31, 2008
    Texas
    Update: Thanks for all your advice. Spring of last year the pump motor bearings went out so I side that as an excuse to redo the whole thing. New pump same size 3 hp but trashed the manifold of valves and ran 2" to each zone with 1-1/2" laterals. I used 1-1/2" valves. Flow calculations allowed me to double the heads per zone.
    Now getting 50 psi +/- to the rotors and half the runtime. Oh forgot to add I used thin wall 200 psi pipe to also help with the friction loss.
    Thanks again for the advice. It helped.
    Terry likes this.
  11. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    It is always best to go with the flow. ;)
    Enjoy.
    PumpMd likes this.
Similar Threads: Pushing lake
Irrigation / Sprinkler Forum Intake piping on bottom of lake Sep 3, 2013
Irrigation / Sprinkler Forum Method to keep irrigation pipe above lake floor Jun 15, 2009
Irrigation / Sprinkler Forum Lake Pump doesn't suck water May 2, 2009
Irrigation / Sprinkler Forum Correct Pump to draw water from lake Jul 16, 2007
Irrigation / Sprinkler Forum water lawn from lake Mar 27, 2007
