Push-Connect (Shark Bite style) vs Compression or Sweat Solder
traCk
South Carolina
Ok guys, first post here. I was looking around at forums that had active knowledgeable people and this seemed to fit the bill.
I have a small plumbing predicament. Roughly 2 years ago I moved into a town home that was roughly 30 years old.
As to be expected every shut off seized up when trying to remove them... No problem.
At that point I sweated new valves on to every connection at the house, except under my kitchen sink.
It was annoyingly tight under there and I opted to use "push-connect" style valves in place.
http://www.lowes.com/pd_4136-143-K2..._product_qty_sales_dollar|1&page=2&facetInfo=
Specifically those...
They essentially work like a "shark bite" style connection.
I have had no issues with leaking or anything but yesterday I replaced my kitchen faucet, i turned the valves off with no issue but much to my surprise
when I went to hook up the hose to the cold valve the entire valve blew off the pipe!
By the time I was able to shut the main off I made a pretty good mess and was pretty upset.
Doing some investigating I found I could push the valve on the pipe and through it would give some resistance I could pull it off the pipe with relative ease
I had a spare valve of the same type when I pushed on and am unable to pull off...
So now I am paranoid, I don't know what failed in the valve or if it will happen again.
I called a few local plumbers just so I wouldn't need to take time off work to repair but all of them are wanting to use compression fittings.
Hell, I am not going to pay someone to put a compression fitting on.
So, finally the question...
Would a compression fitting be a better option than these push-connect style fittings?
Sweating wouldn't be fun in the space I have but it is certainly not impossible, part of me feels like I should give this a shot
but I really don't want to catch my cabinets on fire.
WJcandee
Wise One
New York, NY
A compression fitting is going to give you a more robust and reliable seal than a sharkbite, regardless of what anyone says.
It is also insanely-easy to install -- slip it on and tighten -- so I'm really unclear why you don't just do that yourself... Do you have a sufficient length of copper pipe coming out of the wall? If so, that would be what I would do. We recommend it all the time. You generally need about an inch of pipe minimum, depending upon the particular valve.
Here's a video of a guy installing a compression angle stop. See how easy? http://www.ehow.com/video_2328611_how-hook-up-sink-angle.html
EDIT: Upon rereading your post, maybe your point was that it IS so easy that you don't want to pay a plumber to do it. Got it...maybe. Regardless, it should be an easy enough job to do it yourself.
What material is the pipe? Likely copper at that age. Did the pipe have paint on it, or was it clean? A compression fitting requires the pipe to be clean and not all scratched up, which may be the situation after install of the push-on fitting. The actual Sharkbite fitting has a SS toothed ring that is pretty aggressive to hold it on the pipe. The other's likely use similar. If the fitting was not fully seated, that may have been the issue. The instructions on the Sharkbite have you mark the pipe, then, when pushing it on, verify that the end of the fitting made it all the way to the mark. This stabilizes the fitting and ensures it can properly seal and stay there. The ones you have probably have a similar instruction.
My guess, it was not fully seated.
Dj2
California
Go ahead and sweat the valves on. Done right, no other valve is as good.
traCk
South Carolina
Yeah, sorry for the first post being confusing. What I was getting at was there was no way I was going to pay someone to put a compression valve on.
I have copper coming out from the wall, i think there is a little roughing up of the pipe from where the connector bit in but I think that is further back than where a compression fitting would sit.
This particular Keeney valve does not have any instruction regarding how far up the pipe it should go and therefore it is possible it was not seated, but as I stated on that particular valve I couldn't ever
get that valve to stay properly on the pipe after it blew off but an identical new valve would.
I will take another look and see if I can get a torch up there to sweat them on, but if I can't... would it be the general consensus that a tradition compression fitting
would be more reliable than a push-connect style valve? Or would a proper push-connect like a shark bite be a better bet?
I am actually a master technician for FMC so I am more competent than your average weekend warrior DIY'er
but I certainly am not beyond getting good advice from people who have more experience in a field than I do.
Dj2
California
Actually installing a compression valve requires more working space than sweating. You need enough space for two large wrenches.
When you use a torch against the wall, place a piece of sheet metal as a shield on the wall to avoid an accidental fire - and have a glass of water available, just in case.
If you have to choose between a compression valve and a shark-bite, I'd choose compression.
Gary Swart
Yakima, WA
When I sweat joints in tight locations, I use shield made from a #10 can with top and bottom removed and split down the seam, and a slot roughly cut 1/2 way up a side and about 1" or so wide. You also need to keep a spray bottle of water at hand just in case.
The metal shields help, and, they make spray flame protection foam you can spray on the wall that helps as well. A 1/2" Sharkbite needs about an inch of pipe to seat fully if I remember (it says on the package and varies by the diameter of the fitting). A compression fitting also needs a moderate amount of pipe, as the pipe goes into the valve, then you have the compression ring and the nut towards the outside. If where the compression fitting will sit is smooth ,it will work. If that area isn't clean, then maybe your best bet is to solder on a valve - the solder will fill in minor scratches fine if you clean it up well and flux it properly.
Sweating the valves on is a solid connection, but it is difficult to change the valve when it fails, and it WILL fail, just like all of them do eventually.
Rmk9785e
Stockton, California
I am about to install a hot water recirculation pump on the Hot line of my gas water heater. The connection to the distribution system is sweated on (photo attached). I'm leaning toward using a
Grundfos 595916 1/25 Horsepower Comfort Series Recirculator Pump
here and will probably need to replace the flexible copper pipe with a stainless steel pipe, requiring me to install appropriate male adapter at the distribution end. (I'm thinking the height of the pump above the water heater will not allow me to connect the flexible copper pipe to it.) I had thought of using a Shark Bite adapter but having read through this thread, I'm not sure that would be a good choice here.
Any advice about how to go about installing and connecting the recirculation pump is appreciated.
You disconnect the copper line, raise it up, connect the pump to the water heater, then reconnect the copper line to the pump. you do not normally have to change to a stainless steel connector. But if you have to connectors are available with FIP, Sharkbite, or solder ends.
JamFlowMan
Pennsylvania
It sounds to me like the old valve was improperly removed at some point and it was forced off without retracting the barbs/teeth. That bent the teeth and essentially reversed their direction.
JohnCT
Still learning..slowly
Northeast
That's an old thread, but that's a good theory. Someone could have tried it and returned it to Lowes after forcing it off before OP bought it.
John
