Purpose of Platform Under Toilet?
Discussion in 'Toilet Forum discussions' started by boomer70, Oct 24, 2006.
  1. boomer70
    boomer70 New Member
    Sep 13, 2006
    We're in the process of renovating a bathroom (fixtures removed, floor gutted, etc). The old bathroom had a rectangular shaped marble platform sandwiched between the bottom of the toilet and the top of the floor, offsetting the toilet about an inch from the finished floor. Does anyone know the purpose of this? The marble platform is beyond filthy, and it won't match the new bathroom anyway. Is there a reason why we should be keeping this there? Thanks for your advice.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    It provided a level surface for the toilet to set on. There is no need for one if you can level the floor and if the flange sets level on top of the finished floor. Minor leveling of the toilet can be done with shims if you can't level the floor.
  4. prashster
    prashster New Member
    Dec 7, 2005
    The flange was probably set too high off the finished floor and they had to make the platform so the toilet wouldn't wobble and ride on the flange.
    If your new floor will be installed on top of the old floor then you might be in luck and the flange might sit flush on yr new floor. If yes, then you don't need platform.
    If the flange still rides above the newly finished floor, then you might be able to push it flat to the finished floor if the pipe and trap underneath has sufficient give. if yes, then you don't need a platform.
  5. boomer70
    boomer70 New Member
    Sep 13, 2006
    Thanks for the explanations. They all make sense. This forum is great.
  6. MIDDEN1
    MIDDEN1 New Member
    Oct 26, 2006
    Toilet Spacer
    does anyone know where i can buy a toilet spacer my toilet flange
    is raised up 1 inch from floor in new basement bath.
    thanks
    bob m
  7. Cass
    Cass Plumber
    Nov 12, 2005
    1" is an awfully high marble slab. The ones I am familiar with are about 1/4"-3/8" thick. Why do you need a new one? You may end up having to special ordering one and BTW the new ones are called marble slabs but are not made of marble any more. I would guess a Corian dealer could make you one and would be able to put a decorative edge on it if you wanted.
  8. MIDDEN1
    MIDDEN1 New Member
    Oct 26, 2006
    Risor
    i need a high risor do to i had to raise my flange 1.0 or more above floor in
    basement to get enough pitch for drainage this is a new bathroom.
    trunk line was not low enough.
  9. molo
    molo Member
    Sep 23, 2006
    cold new york
    OK... I'm trying to understand. What is the optimum height for a flange? It's supposed to sit on the finished floor right?
    Molo
  10. jadnashua
    Yes, the flange to toilet design is to have the flange sitting on TOP of the finished floor, and fastened through it. If the flange is too high, the toilet may not sit flat - i.e., rock on the flange, or there's no room for the wax to seal it. If it is too low, you run the risk of having a big torus (ring) of wax that is not strong, and can blow out.
  11. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    drain slope means raising toilet, for Midden1
    Bob (Midden1) said the toilet drain required a slope (normal) and this forced the toilet to sit higher than the existing floor.
    Bob, have you read other threads about sealing around the toilet base? People always talk about leaving a space at the back of the base so you can notice if and when a leak happens. If I had your situation, I would build up a base using ANY material at all that matched the design and esthetics of the space and the other occupants' desires. Any material. You don't need to be told here what the right material is, as there is none "per se".
    You have several ways to choose from, to build up, using different methods. Pillars, flat layering, single-piece (monolith), etc. What might be useful to discuss here is whether to "liquid layer" (i.e. glue, cement, caulk, grout, whatever) underneath and above the material to ensure it touches the floor continuously, with no voids underneath, or to use the pillar method, a practice used in stone-laying. You can layer flat material, in separate pieces, or in whole piece layers.
    David
Similar Threads: Purpose Platform
Toilet Forum discussions Bidet seat installation for medical purposes. Bio-Bidet with remote on a TOTO Drake Nov 1, 2011
Toilet Forum discussions Open front seat - purpose Apr 3, 2007
Toilet Forum discussions What is the purpose of caulk around toilet?? Mar 24, 2005
Toilet Forum discussions Purpose of velcro on tank lid of Ultramax? Mar 18, 2005
Toilet Forum discussions New Toilet Overhangs Existing Platform Jun 22, 2007
