Pumptrol 9013FSG 2 Switch Problems
MNavarette
Tomball, TX
The pump on my well does not kick in automatically. While I was trying to figure out what was wrong with the control system, I tapped on the Pumptrol switch and which turned on the well filling the tank with water. The Pumptrol turned off when it reached it's max setting; however, it does not turn on when even when pressure reaches 0. To start pump once again the Pumptrol needs to be tapped. Does this switch need to be replaced?
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
Just get your significant other to tap it for you. When that no longer works, take the cover off it and wiggle the pressure plate.
LLigetfa
NW Ontario, Canada
My apology for the ascerbic reply. It is a $10 part, $20 tops... so swapping it out is a no brainer. Mineral builds up under the diaphragm preventing it from closing.
