Pumptec Installation
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by neever, Jun 14, 2006.
  1. neever
    neever New Member
    Sep 14, 2005
    I am installing a Pumptec (monitors well pump and turns off if no water) and have a question as far as the 230V. On the wiring diagram it says L1 (from pressure switch) goes to 230 while L2 goes to L2 on the Pumptec. How do I identify which wire is L1 and which is L2 or does it matter? My understanding is each line is 115V but they are out of phase so it doesn't matter. Does anyone know for sure?
  2. neever
    neever New Member
    Sep 14, 2005
    Answer
    FYI: I called Franklin Electric's technical support and they said it doesn't matter which wire goes to 230 and L2.
  4. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    As long as your motor needs 230 volts, either wire from the pressure switch can go to L2 or 230. Then you have a wire from 230 and another from motor going to the pump or L1 L2 of the control box.bob...
Similar Threads: Pumptec Installation
Pumps and Tanks Well Forum & Blog. Water is life. FE standart pumptec, yellow light flicking after pumping cycle Dec 7, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Removing QD Pumptec Nov 29, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Confused about pumptec and control box Nov 27, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pumptec under load and water shooting from relief valve Dec 14, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Pumptec Pump Protector Tripping Dec 4, 2013
