THE PUMPSTOP PROTECTION SWITCH WILL AUTOMATICALLY SHUT OFF YOUR PUMP WHEN ANY PROBLEM ARISES DUE TO FAILURE OF ANY OF THE FOLLOWING:
LOW WATER TABLES, LOST PRIME, CHECK VALVE FAILURE, BAD OR MISADJUSTED PRESSURE SWITCH,
STUCK ON RELAYS, BROKEN ZONE VALVES, PRESSURE TANK FAILURES, BROKEN VALVES NOT OPENING,
EVEN USER ERROR.
ANY OF THESE PROBLEMS CAN CAUSE YOUR PUMP TO NOT TURN OFF WHEN IT SHOULD.
THESE PROBLEMS ULTIMATELY CAUSE THE PUMP TO OVERHEAT DUE TO FRICTION AND THIS WILL LOOSEN OR MELTDOWN THE FITTINGS AND DESTROY THE IMPELLER.
THIS ALWAYS RESULTS IN A TOTAL SYSTEM FAILURE OF THE PUMP, COSTING YOU HUNDREDS OR EVEN THOUSANDS OF DOLLARS IN REPAIRS.
THE PUMPSTOP IS UNIVERSAL, AND IS THE BEST AND MOST INEXPENSIVE WAY TO GUARD THE WHOLE ENTIRE PUMP SYSTEM BY
PROTECTING EVERY ASPECT OF ALL THE ASSOCIATED PARTS OF A WELL PUMP SYSTEM.
PUMPSTOP WORKS ON ANY SIZE PUMP AND VOLTAGE, INDOORS OR OUTDOORS AND IS WATERPROOF AND INSULATED TO ELIMINATE FALSE SHUT OFFS IN DIRECT SUNLITE...
ONE SIZE FITS ALL. EASY HOOK UP IN JUST 5 MINUTES. 12-24-120-240-440 VOLTS @ 30AMPS MAX
ALL IN ONE PRODUCT.
WIRES UP DIRECTLY TO THE MOTOR, OR PRESSURE SWITCH, OR A RELAY, OR CONTROL PANEL
ONCE INSTALLED IT PROTECT YOUR PUMP 24/7/365
FIND THE PUMPSTOP HERE ....... www.overheatprotection.com.
OR CALL FOR MORE INFO AND TO ORDER AT 727-841-7000 or CELL AT 727-277-8202
EVEN USER ERROR.
ALL IN ONE PRODUCT.
