The well is about 40 years old, and is 48 feet deep. There is about 45 feet of horizontal line running to the pump, unfortunately the buried line has two right angles in it, and goes downhill (not uphill like recommended) to the pump, nothing I can do about that. The pump is a newish (10 months old) 1HP jet pump installed at the end of the horizontal line and mounted to a tank. The system was working before replacing the foot valve. The house has had decreasing water pressure for the past few years, and it has gotten to the point where the shower was a trickle, so we replaced the entire foot valve assembly (ejector, venturi, foot valve) to fix this.
Unfortunately it would not re-prime. What happens is it jumps up to 10-40 psi (seems to be random each time) on power up and the pressure needle points around all over the place, then as soon as you turn the pump off (or open up the valve on the regulator), it falls back down to zero. After two days of attempting to get it to prime, we pulled the foot valve back out and cut the hoses off the ejector, the smaller of the two (the 1" pressure pipe that sends water back to the ejector) had about 1 ft of densely packed sediment jammed onto the bottom where it meets the foot valve, and the larger hose had a little bit, but not much. Clearly we were getting sediment that clogged everything. So we cleaned out the vertical lines, reinstalled the foot valve, and tried again. A few hours of priming with no success later, we pulled it back out, and once again, about a foot of sediment clogging the bottom of the small hose where it meets the foot valve.
So we called a well expert to clean out the well, $400 later the well is now 5' deeper, and free of sediment. We hooked everything back up, went to prime it. Nothing. Tried about 40-50 times to prime it, maybe more, and I'm not getting a thing. I'm about to pull the foot valve back up again, because I'm assuming it's clogged, but my question is, where is all this sediment coming from?
My only theory is that the horizontal lines have caked in sediment which has built up the past four decades, and that the loss of pressure when we replaced the foot valve caused it to come loose. And then when we re-prime, it breaks it up and the pump shoves it all down the small line to the foot valve where it gets compacted and clogs up the whole operation. But I have no earthly idea how to get those horizontal lines unclogged, we've run a garden hose through using the neighbor's water, and we're getting crystal clear water out the other side! Where is all this sediment coming from, and how can we fix this?
Thank you for reading this novel of problems, I'll appreciate any help I can get.
