Pump will not turn off
Discussion in 'Pumps and Tanks Well Forum & Blog' started by morgans, Aug 27, 2009.
  1. morgans
    morgans New Member
    Aug 27, 2009
    My well pump usually runs at 50psi pressure. It has been running at 30psi and will not turn off. When turn off the water to the house and out side the pump still doesn't turn off. The pressure went to 40psi.
  2. Waterwelldude
    Waterwelldude Well driller,pump repair. and septic installer
    Feb 11, 2009
    Texas
    You have a hole in the drop pipe or the pump is bad, if it is a submersible.
    If you have a jet pump, there may be some trash in the jet orifice.
    Travis
Similar Threads: Pump turn
Pumps and Tanks Well Forum & Blog Well pump only works when manually turned on Apr 25, 2016
Pumps and Tanks Well Forum & Blog Pressure falls after pump turns off, but levels out Jul 22, 2015
Pumps and Tanks Well Forum & Blog How often should the well pump (submerisible) turn on? Dec 29, 2013
Pumps and Tanks Well Forum & Blog Turning on a deep well pump without a pressure system? Nov 14, 2012
Pumps and Tanks Well Forum & Blog Delay from when pressure switch clicks and pump turns on Aug 21, 2012
