pump taking long time to reach cut off!!
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Bennet Young, Sep 30, 2006.
  1. Bennet Young
    Bennet Young New Member
    Dec 23, 2005
    I have a 3/4 hp shallow well goulds pump, about 9 months old, and a new bladder tank as well 40 or so gallons. The pressure switch is a 30/50. No problems til recently. The pump lost prime completly. We changed the check valve on the poly right before the pump and we dug up around the well and changed the well adaptor. Good thing too, it had eroded and had huge openings on it, its amazing we could keep prime. The system did well for a couple days. When it was running great it would only take 3-4 minutes from cut in to cut off. That was regardless if water was on in the house or not. However, the last week when the pump reaches 30 and kicks on it just stays at 30 for 10 or more minutes before finally it powers back up to 50 and cuts off. The time it takes to reach cut off seems to be getting longer as well. Though It seems to hold pressure after cut off as.
    I am perplexed:
    Is my well going dry?
    Is there a crack in the block poly somewhere?
    Would a bad foot valve at the well cause something like this?
    Help!!!!!!!!!!!!!!!!!!!I don't wantmy pump to burn up. What could it be?
  2. Pumpman
    Pumpman Pump Sales
    Apr 12, 2005
    Owner - R.L. Peeks Pump Sales
    So. Cal
    The nozzle in the pump could be pligged up. On the Goulds shallow well pumps there is a pipe plug directly underneath the suction port. Remove this plug, and using a piece of wire, you can clean out the nozzle. Once it's clean, the wire should go in about 6" or so.
    Be sure you shut the power off and drain the pressre down before you remove the pipe plug.
    Ron
  4. Bennet Young
    Dec 23, 2005
    tried the nozzle cleaning
    I did as you suggested, it's that big bolt plug below where the first pipe enters the pump right? If so, I was able to put the wire in all the way on the first try, no resistance or sediment visible, still went through the motions. We will see how fast it reaches cut off. Any other suggestions to why it is taking longer and longer to reach cut off?
Similar Threads: pump taking
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Yesterday at 7:51 PM
Pumps and Tanks Well Forum & Blog. Water is life. Well pump varies, Please help I'm clueless Wednesday at 9:38 PM
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well jet pump failing to reach cutoff Wednesday at 7:59 AM
Pumps and Tanks Well Forum & Blog. Water is life. Poly vs schedule 80 pump vibrating loose Tuesday at 12:36 PM
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump Malfunctioning Feb 11, 2017
